04-20-2020, 03:36 PM
Batteries and slide
We bought brand new batteries last Labor Day for our 2018 Isata 3 24 FW. Since this was our first winter with it I had my poor hubby remove them. I found out I didn’t have to remove them if plugged in. Learned a big lesson there. Anyways
We took a 8 week trip last summer. Every so often when stopping for the night I get the fault code Low Voltage:Start and run coach. I never try putting out the slide without either plugged into shore power or the generator running. Should I be concerned?
04-20-2020, 04:28 PM
On your 8 week trip, were you always plugged in to shore power or sometimes using the batteries? If you were plugged in I am surprised you got the low battery alert.
One comment, when you start the generator to open the slide, you must wait about 30 seconds for the transfer switch to engage to actually get power from the generator to open the slide.
2021 Isata 5 30FW
2014 Honda CR-V
04-20-2020, 07:39 PM
Mine works best after the generator has run for a bit. On shore power I get the low voltage light at times. I think the converter does not put out quite enough voltage to make the slide happy. When I get the light I stop for a few seconds and run it some more. It sometimes takes 2 or 3 times of starting and stopping to get the slide in or out. This procedure works fine for me. I’ve never had an issue using this method. It also does better in warm weather. As long as you don’t keep running it with the red light on you won’t have a problem.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Also,3 Diesel pushers, 1Bvan, 2 class Cs
04-21-2020, 08:45 AM
I don't have a Sprinter chassis I have the Ford on a 31DS. I have found that the alternator on the vehicle does a much job of providing the power needed for the slide to operate without a fault or red light. I am sure the Mercedes has a very high output alternator so I would think that would work fine. I have found that even when plugged in or generator running the voltage drops enough to cause the light to come on. Sometimes when you first start the vehicle the system does not connect because the alternator is taking care of the chassis battery. I would have to wait until it would connect before I moved the slides. This was tedious so I changed out my momentary switch with a switch I could flip on while moving the slides. This has really helped the situation. The switch I installed has a bright light so I don't forget to turn it off. I believe the Ford comes with a 130 amp alternator which is much better than the 60 amp converter/charger that is installed in the coach. It just makes sense that the alternator would handle the job much better.
Hope that helps.
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
04-21-2020, 09:00 AM
Hope that helps.
The Mercedes alternator does the job, but you have to wait a while for it to kick in on the house battery’s. The problem with that also is that the Isata3 on the Sprinter chassis has a lock out so you can’t move the slides with the engine running. I did re-wire mine to eliminate the lock out but I’m assuming the OP hasn’t done that. I was trying to help him because we have the same vehicles and I’ve experienced his issues.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
04-21-2020, 09:41 AM
Seems silly to have a lockout. Just make so the emergency brake must be applied like my Ford
Bill & Sue
04-21-2020, 10:14 AM
I agree, that’s why I eliminated mine.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
04-21-2020, 01:44 PM
Commercial Member
So did we, E-brake lock out only on new vehicles.
04-21-2020, 02:03 PM
Great!
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
04-22-2020, 08:15 AM
Yes always. It’s scares me extending and retracting so am very aware of not using just the batteries Thank you for your quick response though
04-22-2020, 08:18 AM
[emoji106][emoji106][emoji122]
04-22-2020, 08:39 AM
Hmm.... disabling the lockout sounds great.... can anybody explain how? (2017 Sprinter)
Hans
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - Sep 2021
Entegra 27A Oct 2021 - ?
04-22-2020, 11:50 AM
Hans
There is a post somewhere on this forum on how to do it. It was a couple years ago
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
04-22-2020, 11:56 AM
I found it but I don’t know how to post it. I did a search for slide lock out and found it pretty easy.
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
04-23-2020, 07:49 AM
Retired military
04-23-2020, 12:19 PM
Commercial Member
that's the one. Goes from engine to E-brake lock out. (at least on the Isata 3).
