Originally Posted by pelikan61
That makes a whole lot of sense. Appointment is on the 6th off July, is it something easily swapped? If so, I’ll do it myself.
Thanks for the info.
The isolation relay could be easily replaced, but it may not actually be defective. There is a part of your description causing me to suspect that that the isolation relay is always energized (causing batteries to discharge) due to either: 1) a manufacturing mistake, or 2) a defective relay or switch associated with your ignition system keeping the isolation relay energized. I demerit the first idea because that would have been impossible for a dealer to ignore. I think the second idea more likely simply because all was good for while, then something went bad. Additionally, the first idea would be repaired by Isata; the second belongs to Mercedes, and may be more complicated to repair. If you have warranty – use it!
