Old 03-20-2021, 11:10 AM   #1
Battery disconnects ... do they really?
Our 2018 Dynamax Force HD 37TS has 2 battery disconnects - one in the basement battery compartment for the house batteries and one under the drivers seat for the starter batteries. When I put the RV in storage at the end of the season, I always turn the disconnects to the Off position.
But when I went to take the RV back out of storage a few days ago ... you guessed it, dead as a doornail. Both systems. We were able to jump and get the coach started. And now we're plugged in so everything is charging back up.
But why don't the disconnects keep things from discharging? Isn't that the whole idea behind having them? And, if I doing things wrong, what can I do better to keep this from happening?
Thanks, Bill
WrkdbfGuy is offline   Reply With Quote
Old 03-20-2021, 11:19 AM   #2
batteries naturally lose charge in storage no way around it
2016 wildwood x-lite 241qbxl
being jurked down the road by the beast 2007 Dodge ram 2500
5.9 cummins g56 Trans southbend clutch and a smarty
railroaderone is offline   Reply With Quote
Old 03-20-2021, 11:31 AM   #3
The terminology of battery disconnect because my on or off drives me crazy! When you have your switches I the on position does that mean the batteries are Ďonlineí (connected) or the the disconnect is on, which disconnects the batteries? Then there are the parasitic loads that stay connected to the battery regardless of the position of the factory installed disconnect switch. A fully charged battery should make it many months if all loads are truly disconnected.
I had similar problems until I installed my own disconnect switch right at the battery that disconnects all loads.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 03-20-2021, 12:21 PM   #4
Webefine's Avatar
I use the same two disconnects as the op and my batteries only lose about .2 to.3 volts in three months of storage.
Webefine is offline   Reply With Quote
Old 03-20-2021, 03:03 PM   #5
I had the same problem as the OP. My Guess is that I had the entry stairs out while stored even while plugged in!. Came back and the stairs were partially retracted with dead batteries. I don't believe that the BIRD had closed the relay allowing the chassis batteries to be all by themselves.
I replaced the BIRD and solenoid and things still were not correct. Then I happened to do a fast idle on the engine to use the air tanks to air up the tires. The solenoid closed and all is normal. The BIRD needed fully charged chassis batteries to close the solenoid. After that the house batteries kept the chassis batteries charged.
Now my observations and conclusions could be wrong! Wouldn't be the first time. So, FWIW. BTW, the stairs are directly connected to the chassis batteries all the time.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2018 RZR XP 1000 Ride Command
rskeans is online now   Reply With Quote
Old 03-20-2021, 03:14 PM   #6
Motorized GM
By code not all items can be disconnected. Steps being one...they need to be able to extend and retract no matter what.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
bclemens is online now   Reply With Quote
Old 03-20-2021, 04:21 PM   #7
Webefine's Avatar
I just pulled my DX3 out of storage today. It has been in storage since the middle of December unplugged with the disconnect in the battery compartment off and the disconnect inside the drivers door off, temperatures as low as 0 through the winter. I checked the voltage of the chassis and coach batteries before trying to start and both were at 12.4 volts.
Old 03-20-2021, 04:32 PM   #8
Were the steps retracted during storage?
2019 Rubicon JLU
Old 03-20-2021, 04:49 PM   #9
Webefine's Avatar
Yes
Old 03-20-2021, 05:30 PM   #10
Webefine's Avatar
It doesnít seem right to me that the steps would need power to stay out but maybe so.
I am going check this while mine is sitting at the house. Iím going to leave it unplugged with the steps out and both disconnects off, I will then check the voltage every few days to see if there is any noticeable voltage drop.
Old 03-20-2021, 05:34 PM   #11
CO/LP sensor being another?
- 2016 Ford F-150 SCrew Lariat RWD MaxTow
- 2020 Rockwood 2507S
chriscowles is online now   Reply With Quote
Old 03-20-2021, 06:15 PM   #12
Webefine's Avatar
Those go off with the main disconnect on my RV
Old 03-21-2021, 01:18 PM   #13
Bob2019's Avatar
The only and I mean ONLY was to insure all loads on the batteries are disconnected is to install a battery slide blade switch on the negative cable side of the battery. Have one on the coach battery for the winter and also on the house batteries. The battery voltage is slightly lower than when put away in the fall, but everything works and can be started. Ck Amazon for slide blade switches. They don't cost that much and sure beats a dead or ruined battery.
2019 Forester 2861DS
Bob2019 is offline   Reply With Quote
Old 03-21-2021, 02:08 PM   #14
Originally Posted by Bob2019 View Post
The only and I mean ONLY was to insure all loads on the batteries are disconnected is to install a battery slide blade switch on the negative cable side of the battery. ...
If proximate to the battery, connections to the existing cutoff switch can be rearranged to accomplish the same thing for the house bank, at least. I did that on my Mini-Lite by moving a couple of wires from the hot side to the switched side.
Old 03-21-2021, 02:10 PM   #15
Mr Clemens, you say some devices must stay connected to the batteries. You mention steps. Also the emergency brake circuit is usually wired directly to the battery bypassing any disconnect switch. I donít have an issue with these as long as there is a make or break switch (on / off) in their power circuits. By breaking these power circuits there will be no current flow thus no battery drain from these on / off devices.
But I think I found 5 devices on our trailer that were always on. Devices such an propane sensor, co sensor, stereo, slide out controller (it has a remote and must always be listening for the remote), and I believe the inverter still draws some power even when it is off.
So with all these always on devices, what is the purpose of installing a factory disconnect that doesnít truly disconnect the batteries? And for all of us that have installed our own true disconnects, are we going to go to disconnect jail when the weight police stop us and discover the supposedly illegal disconnect?
Old 03-21-2021, 04:41 PM   #16
Now you are really in a heap of trouble. LOL
2019 Rubicon JLU
Old 03-21-2021, 05:00 PM   #17
Are you suggesting a manufacturer should ignore building codes?
Old 03-21-2021, 06:33 PM   #18
Batteries
I always lost a lot of power in my house batteries.
I found it better to physically disconnect them if I wasn't going to use the motor home in more than a week.
I take them right out for the winter, here in Canada, store them in the basement and give them a slow charge every month or so, until I re-install them.
Cold Lake Kid is offline   Reply With Quote
Old 03-21-2021, 08:08 PM   #19
Thanks, Bill
By bitter experience I've learned the best thing I can do is take the batteries out and put them on battery chargers/ maintainers over the winter. I tried solar charging but the lack of full sun wasn't enough to keep them from discharging to critical level. I yanked them out ,brought them home and put them on chargers that brought them up to full and then maintained them
My suggestion is you do the same
Nomore9-5 is offline   Reply With Quote
Old 03-21-2021, 08:50 PM   #20
There is a special police force checking for battery disconnects that shut off everything. A branch of the force that looks for people who cut off the "do not remove under penalty of law tags).
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
battery, battery disconnect
