bclemens leaking drain valves
bclemens
2015 Dynamax REVrb VIN 3C7WRVLG3EE116378
The LaSalle Bristol 66N4AB48BM 3" x 48" Term Valves are broken and leaking. The grey valve will only close 1/2 way. I need to replace both of the valves. They are both 3 inch. It appears that they attach to the tanks with screw type hose clamps. They would be glued to the 3" Y. The dealer replaced it a couple of times because they would drag because they were lower than the skids. He just added a sewer hose connection to the end of the Y and that has worked. I need the Y, 3" valves and 3" hose connection to add to the Y.
Information please
Thanks Tom D Orlando
