Old 04-22-2024, 02:28 PM   #1
Bedroom Reading Lights
Anyone ever have only the right reading light controllable for the pad on the bathroom wall but the left works fine from the main control pad. This is one of the last things keeping us from taking delivery.
This is an Isata 3 24FW Freedom
llwill is offline   Reply With Quote
Old 04-22-2024, 02:53 PM   #2
Commercial Member
The reading lights are individually controlled from a switch ON the light. Once you turn them on from the control pad, the lights are hot. Then you can turn them off as you want so one of you can go to sleep and the other leave theirs own. It might just be off at the fixture.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-22-2024, 02:56 PM   #3
Commercial Member
I did it that way, so if my wife came to bed LAST, without turning the lights off, (and refused to get back up since she was now already under the covers) I can turn them all off from the app.
Old 04-22-2024, 03:32 PM   #4
So are you saying that the left light should not be controlled from that panel?
Old 04-22-2024, 03:36 PM   #5
Commercial Member
No. I am saying BOTH lights are controlled from the panel, but they also have an individual switch on the fixture. So, if the left light is turned off at the fixture, then turning the light off/on at the panel will only work on the right one.
You need to turn the right one on, then touch the little silver disk on the left light fixture to see if it is just turned off.
Its like two floor lamps in your home, plugged into a switched outlet. You can turn the switch on...but if the lamp is off, then it won't matter.
Old 04-22-2024, 03:38 PM   #6
Ok we are having a problem because there is no control from the wall panel for the left light. If you could send McKee RV more help it would help.
Old 04-22-2024, 03:40 PM   #7
Commercial Member
So if the right light is on....you are saying you can't turn on the left light at the little switch that is on the actual light?
Old 04-22-2024, 03:49 PM   #8
Commercial Member
Each light is individually switched (if the wall panel is on)
bed, bedroom, light, roo
