Big Foot connection issues
I have a 2016 Isata 3 - with the Big Foot system. The only control is a toggle switch for EXTEND and RETRACT.
The unit stopped working, went under and had a look and found a corroded small red wire that had broken it's connection that it shares with a a main red power cable. I jumped a wire across to see if that was the problem - it was!
The power cable is hot - where do I disconnect power to the system so I can correctly reconnect the small red wire? (control wire I'm guessing - do not have a schematic).
Pat Geraghty
