Old 04-03-2020, 11:44 AM   #1
Black Tank valve leaks need advice.
Recently took delivery on 2021 Isata 3 , figured it was time to un winterize it in case we can find somewhere to go.
When I unscrewed the drain cap I thought it unusual that a couple gallons of Rv antifreeze drained out. I wanted to test out the holding tanks to be sure of no leaks . Grey talk holds fine , of course it’s the black. So now on my brand new Isata if I use it I can leave a full pipe of sewage when I take the cap off prior to opening the valve.
I am looking for suggestions to solve this I have flushed a couple tanks of fresh water with same results.
Xvatorguy is offline   Reply With Quote
Old 04-03-2020, 11:55 AM   #2
SailorSam20500's Avatar
Initial thought, can you reach the valve blade? You may have a piece of construction debris in the valve seat. Just rinsing may not be enough to dislodge it. Next thing I would do is disassemble the valve to check for damage. You're lucky in that it's all still clean.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 04-03-2020, 12:09 PM   #3
Semperfi24's Avatar
That is an unfortunate scenario. We just got a new 5th wheel back at the end of November, and we had the same problem. Lucky for us, it was the gray and not the black. But, the process to fix will be the same. We figured, if we have someone fix it for us (mobile tech 45 minutes away) or bring it to the dealership (4 hours away) the time, and diesel, etc just isnt worth it. So we bought a new valve on Amazon for like $14. Not sure the cost for the black valve as it is larger diameter pipe. With the tank empty (if it has been used, I would really flush it good if possible), remove the 4 bolts on the valve, Separate the pipes from the valve, and pull it out. Then separate the pipes, slide in the new one, and install the 4 bolts and done. It is literally a 10 minute job. Be mindful you dont over tighten the bolts. But other than that very straight forward and simple to do. Its frustrating to have to do it on a new unit, but it just seemed like something that was not worth the trouble to have it fixed, and I just did it myself. Your other option, remove the current valve, give it a clean, lube it, and put it back in. Possible one of the rubber washers didnt seal right.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
Semperfi24 is offline   Reply With Quote
Old 04-03-2020, 12:17 PM   #4
milkman55's Avatar
You may know this, but the actual valves are on the passenger side of the RV opposite the drain handles. If you look under the passenger side, can you see if there are any issues where the cable joins the valve? Have someone operate the valve handle and see if you spot any issues. My bet is also on construction debris keeping the valve partially open. If you open the toilet and use a flashlight, not sure if you can see the seal? One of the unfortunate things on the Isata 3 is the extremely long cables needed to reach the actual valves.
2021 Isata 5 30FW
2014 Honda CR-V
milkman55 is offline   Reply With Quote
Old 04-03-2020, 01:43 PM   #5
Sandiegodoug's Avatar
I added a valve on the end of the exit pipe, and a small clear piece on other side. I don’t open till hocked up to dump. Sometimes a piece of toilet paper can prevent closing. I also move valves open and close while rinsing to prevent any debris getting stuck.
Sandiegodoug is offline   Reply With Quote
Old 04-03-2020, 01:47 PM   #6
You need one of these:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-03-2020, 02:03 PM   #7
That’s what I installed, with a clear piece on other side to monitor cleaning
Old 04-03-2020, 02:35 PM   #8
While those valves that turn onto the end of the sewer port work, you really should fix it correctly in case you ever want to dump just the grey and not the black. You've been given some good advice on how to do so.
Another thing to check... there have been many, many reports of the cables that actuate the valve having issues. Many are routed improperly and bind to the point it doesn't close the valve.
If you have cables to the valves, check them too.
It should be under warranty and you shouldn't have to buy or fix anything.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 04-04-2020, 12:00 AM   #9
I had black tank valve problems a while back. Replaced with electric valve. Much better
Harkerr is offline   Reply With Quote
Old 04-04-2020, 08:56 AM   #10
Get a drain cap with a hose connection. Put a bucket under the fitting and open the hose fitting cap. it will drain at a slower, yet manageable rate
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 04-04-2020, 09:05 AM   #11
Chuck_S's Avatar
Ya really need a good valve at the black and grey tank drains. An additional valve where they both exit to the sewer is an OK backup but you need to close the grey valve to avoid contamination with black stuff.
Silicone spray on the valve blades frequently is all ya need to restore their sealing and operation. If not replace the entire valve. I think I've done it twice on my black tank, never on the grey. Yeah, it's a poopy job.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 04-04-2020, 09:30 AM   #12
Commercial Member
Not unusual...if its brand new, maybe the valve did not seat properly. I'd open and close and test with fresh water for a bit. See if you can clear the debris, or as others have said look at how the cable is routed for the valve. Make sure its not kinked or has a sharp bend.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-04-2020, 01:19 PM   #13
Originally Posted by Reverse_snowbird View Post
Hard to answer your question without knowing the location of your black tank relative the sewer drain. As far as I can tell, what you're dealing with is a common design issue not something that can be repaired. The solution suggested above is simple. That device is sometimes called a line end shutoff or something like that. Same thing happened to me with a new fifth wheel. There's a pipe run of about 15 feet from the tank to the drain point (where I attach the drain hose). The valve for the tank is close to the tank, So that 15 feet of pipe may contain several gallons of waste water even with the tank valve closed. So when you undo the drain cap, you get a messy bath. For me it was grey water that came gushing out. A little research on this site led me to that line end shutoff valve which attaches where you attach the sewer hose and has a bayonet connection to attach your sewer hose to. I mounted mine semi-permanently using gorilla tape. When I need to drain my tanks I remove the cap, hook the hose to the added valve and open it. Any waste water in the pipe goes out. I then drain the tanks as usual. When I'm done I hope to remember to close the drain end valve and replace the drain cover.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 04-04-2020, 03:20 PM   #14
How to spray silicone onto both sides of drain valve, even if closed
-- Chuck
I drilled into the plastic housing above the pull sliders for my black and gray drain valves. Then, I installed a nominal 1/8" brass plug into the holes. (Buy the plugs at your hardware store to figure out what drill size to use. I actually used a tap to put in proper pipe threads.)
This area does not get tank fluid on it at any time, so there is no risk to getting sewage backing out of the hole.
When the valves get a bit sticky, I remove the plugs and spray silicone into the holes. I can do this when the valves are closed if I am having trouble opening them. And, when the tanks are drained, I spray silicone into the holes while operating the slides back and forth.
It works like a charm. Photo attached.
–Gordon
Name:	Plugs to allow silicone spraying of drain valves.jpg
Gordon Sick, Calgary (51° North)
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...ml#post2579202
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 04-05-2020, 09:15 AM   #15
Oldnapapartsguy's Avatar
–Gordon
Nice fix! I might just copy that. Thanks for sharing.
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
Oldnapapartsguy is offline   Reply With Quote
Old 04-05-2020, 07:29 PM   #16
After several full tank flushes it has appeared to of cleared any debris. Thanks for all the suggestions.
Old 04-05-2020, 07:57 PM   #17
Maintenance Engineer
I had the same problem, didn’t get lucky like you and had to actually change the 3” blade, on a not new system. Its every thing you’d imagine it to be when taking out the 4 bolts and pulling the old assembly and seals out, maybe worse.
Getting the old one out is messy but very easy. Getting the new one in while keeping the seals in place on both sides of it not so easy. I had to take the valves for the black tank, grey tank and galley tank apart, all the hangers so I had room to slide opening apart enough to get the new blade and seals in. I decided I didn’t want to put it all back together just to test for leaks and find I didn’t get a seal back in and have to take it all back apart/together again so I went to Home Depot and got a 3” black ABS union I added about 3’ down stream of the valve, like the factory should have done from the start to make it all easily serviceable in the future.
Ampdraw is offline   Reply With Quote
Old 04-10-2020, 07:00 AM   #18
Not that lucky,just slowed the leak about a gallon a day. What valve is used on new Isata 3 . Would like to replace the seals before its used.
Old 04-10-2020, 08:26 AM   #19
our black tank valve leak was caused by a poorly routed cable. not hard to fix once you gain access. had to cut through the coroplast. it's amazing how well it works once the cable was able to move freely.
i also bought one of those valterra screw on valves so at least i did not get a rush of liquid every time i opened the cap.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-10-2020, 09:21 AM   #20
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I hope it's not something like this you're dealing with.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
black, black tank, leak, tank, valve
