04-02-2022, 02:51 PM
#41
Originally Posted by MoJoe1003
Are you seeing an actual code of some sort on the WABCO? Mine fires right up and the WABCO works fine. Seems so strange you and Andy are throwing codes and I’m not on the exact same setup.
My Wabco was throwing an actual code and the screen turned red. That's why I didn't want to leave it plugged in. Unfortunately, I didn't write it down or get a picture of the the actual code. :-\
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
04-02-2022, 02:57 PM
#42
Sounds like I’m going to leave well enough alone and be glad mine is working. When I did my first test drive of the new rig last June, my WABCO was not working at all and kept showing a red screen. Ultimately, Dynamax had to send it back to Freightliner to get it straightened out. I don’t remember if I had the BlueFire swapped from the old unit at that point. Pretty sure I didn’t, so probably not the same issue.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
05-02-2022, 10:18 PM
#43
I believe I’ve isolated it to whether or not cruise control switch is on when engine started. If cruise is on, the wabco trips out about 5-8 times then disables cruise with a no acc on display. If started up with cruise switch off, all is well. Cruise works just fine once rolling.
I just have the scangauge plugged in. Will use the BlueFire when needed. It comes with a nice storage case.
Head scratcher…
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
05-03-2022, 07:49 AM
#44
My cruise control doesn't work if it is ON when the engine is started. The rocker switch lights up, but you can't set the speed. Turn it off/on and it works normally. I can't say if this is what it did prior to installing the Bluefire because I put that in pretty much right after I took delivery.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
05-03-2022, 07:55 AM
#45
Assuming your rig is not equipped with the Wabco adaptive cruise deal right? Maybe just having the cruise control switch in the on position when starting is what is irritating the Wabco. It beeps and blinks orange a handful of times and then ends up stating NO ACC, no matter what I do with the cruise switch, it just won't work. Glad to hear that maybe this isn't a problem with add-ons in the 9-pin OBD jack.
I've had to shut down the engine and re-start with cruise off if I wanted to use it. All operates great that way.
Jim
05-03-2022, 08:29 AM
#46
Correct. No Wabco in mine. Wish it did.
05-03-2022, 01:48 PM
#47
My cruise control switch is on 100% of the time. Wabco works on startup and with BlueFire every time.
Joe & Cynthia
05-03-2022, 02:36 PM
#48
Steve & Linda M.
Which engine ? Cummins or DD8 ?
Started in the "Pumpkin" '79 Burnt Orange Dodge "Street Van" ... NW cruise, Canadian Rockies, Round trip to Alaska. Then' 94 Tioga Montara, '06 Jayco Jay Flight 5th Wheel. Workmanship decline started : '15 Thor Siesta & '17 Tiffin Breeze.
Another RV learning experience with our 2022 34KD Force.
2019 Jeep KL (Cherokee) TOAD
05-03-2022, 02:40 PM
#49
MoJoe and I both have a 2021 XL with Cummins 450hp/1250tq L9.
Jim
05-03-2022, 03:09 PM
#50
Steve & Linda M.
That may explain the difference as the OP was about a '21 with a DD8.
05-03-2022, 03:47 PM
#51
Cummins
Joe & Cynthia
