Originally Posted by vrunner
Ok we bought a 2018 35DB site unseen as of yet frim the Hersey show and am picking it up next week. I had few questions.
How long does the frig run on the inverter/batteries? Does the front TV/bunk TV power up while in motion off the inverter?
What outlets are operational with the inverter on? How loud is the diesel gen vs gas?
Does the unit have side cameras as well as rear?
Is the blue tooth module part of the unit now so we can link it to our phone?
Is there a temp control for the insta hot water heater?
Coming from a Jayco Greyhawk so trying to pick up on the differences. Thanks!!
Hi and welcome to the Dynamax family and I5 ownership.
I have a 2017 I5 DS. So there are a few minor differences as Dynamax continues to improve the unit. So I will answer your questions based in my unit.
The inverter runs everything in the coach when not on shore power or generator. I have 4 coach batteries. The frig has run for more than a day on battery only and didn't drain the coach batteries. Not pulling any other heavy elec load expect lights and maxx air fans. Other main factor influencing length of use is temp. If coach temps are 85+ then frig runs more.
Yes Tv will run on inverter. The issue while in motion is tv signal. But can watch DVD.
Diesel noise. When idling it is louder than gas. When cruise 65 in the highway same as gas. Pulling big hills about the same or a little noisier than gas. Down big hills, using tow/haul mode and exhaust break noisier than gas...but this is a good as not using the brakes. I really like the cummins and wouldn't trade it for a gas engine. It is quieter than the class C gas unit we had before.
Mine is a early unit so no side camera or rear camera that is on all the time. Only backup camera.
Are you referring to the Bluetooth module for controlling, lights, slide outs, generator, etc? Wasn't on mine but I bought it for $200 from Precision. Works good.
The only temp control I have found on the Truma is "comfort" and "Economy". This is for the tank water temp and freeze protection. I don't think it changes the water temp when making hot water under demand.
Be sure you do a complete PDI with dealer working all components and testing plumbing, etc.
Congratulations on your purchase. It is a great unit.
