Brian Battery problems 2015 REV RB
On going battery problems.
Currently it will not switch to battery when the AC power is disconnected. I have taken the drawers out to access the electrical systems behind them. I found the left side of the silver Cole Hersee relay wire was loose from the lug. Also it was not hot to touch like always. When I took it off the back wall, the left wire came completely out of the lug. I replaced the lug and reinstalled the Cole Hersee. It is now getting hot to the touch and the bar to the left (bird) led's are now working.
Still if I turn off the 120 circuit breaker, all power goes off.
Our July trip to Ohio, sometimes we had battery power and sometimes not.
Two days ago I accidentally hit the battery cut off switch (It's just above the light switch) The steps wouldn't go back in. The battery cut off switch isn't switching the black battery cut off relay. I can short from the 12 volt power junction to the right side of the cutoff relay and get it to change state, but not with the switch. The switch is in working order and the wires are connected to it.
The battery disconnect is KIB Battery Disconnect Latching Relay #LR9806CBIP
I'm stumped.
What part auto switches to battery for the lights when the 120 power goes off?
Thanks in advance
Tom D Orlando
2015 Dynamax REV RB
