Broken Entry Threshold (top step)
The metal threshold on the top step has pulled away from the floor and when you step on it has no support so you foot slides off. Found it by stepping on it and then bouncing down the steps and out the door onto the ground.
If you step on it you can see a couple of screws that probably should have held it in place. when you move the threshold the screws do not move so their heads probably have pulled through the front of the step.
See attached picture looking down from inside coach.
Looking for some repair advice before I start pulling things apart.
It appears the screws that should be holding it in place are behind the rubber mat on the vertical face. Should I peel that off or does the Al top piece snap off?
2017 Isata 5 DS
