Cabin Air filter
Don't forget to change out those cabin air filters. I'm the second owner and I don't think it had been changed. It was full off carpet pieces. Advance Auto in Texas had it in stock. Get out your Torx bits. You can't can't use your screwdriver on the top screw. I took the bit out of the driver and used a small adjustable wrench. Also included was a small rubber piece that went into a groove at the bottom of the faceplate.
DYNAMAX 2016 FORCE HD
