I have had issues with my cameras all stop working for about 50 percent of the time- I have had the dealer try to fix this issue 3 different times and they have not found the problem. Has anyone else had this problem?
Sounds like make a loose wire into the video module or a bad video module. That device is under the driver seat as I recall. Connex...Sometimes the video plug (which is an RCA cable) is not pushed all the way on. I had a similar issue with a sub-woofer in my house recently. I had no idea there sort of snapped into place (at least on the sub). I had to push pretty hard.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
I have a 2018 Isata 3 and had all go at first intermittent then out for good. B Clemmons is correct on the location of the module. In my case that was the culprit. It was dead.
