Someone named bclemons posted the Arcadia cut sheet on the Solera forum back on 2-06-15
http://www.forestriverforums.com/for...ain-74941.html. Good memory, Brian. But yeah, reversing that shower opening is probably an improvement you could look into when you re-start production on the 25FW.
That sales sheet doesn't help me with reversal, but I'll save it anyway. Surely your factory guys have some assembly instructions, or do they all come mostly assembled right handed?
The reason I am pursuing this is that I have a repair appointment in a couple of weeks to fix the black tank flush line that is not connected under the shower. You checked w/ engineering and found that the repair involves removing the shower pan, so that would be the perfect time to get the curtain reversed. I trying to get some decent instructions to give the repair techs, so that the shower reassembly is not a major modification that they would not be willing to do as part of warranty work. Otherwise, I'll do it myself.
Just for the record, I expect they will also have the toilet out to fix the leakage there, so lots of work will be going on in the bathroom.
http://www.forestriverforums.com/for...ts-190167.html
