Old 09-19-2020, 10:02 PM   #1
EdandShelley's Avatar
CB Performance
Many have experienced the less than desirable performance of our Freightliner M2 CB radios. We have tried new antennas and a new head unit but continue to get low range and difficulty tuning.
Decided to do some troubleshooting. I bypassed the OEM CB cable and ran directly from the head unit to the antenna on the mirror. Wow...what an improvement. So, we know itís the original wiring. Time for an upgrade project.
I purchase the FireStik K-9 Fire-Flex Dual Antenna Coax Cable from Amazon and began the installation. Am going with a dual antenna on the passenger mirror...just because I can and it will look cool...and have time between trips.
What I found was incredible.... instead of a solid antenna cable run from the head unit to the mirror antenna...we have 3 connectors linking 4 pieces of antenna wire together(plus a firewall connector)! Makes sense for building the cab on Freightlinerís production line but really not good for how a CB wire should be ran as one continuous run. Iíve included some pictures and will report back when we complete the project.
Connection in the door
Connection in the windshield pillar
Connection through the firewall
EdandShelley is offline   Reply With Quote
Old 09-20-2020, 12:34 AM   #2
Send a message via Skype™ to toshu
OMG.....get a local ham operator to lend you an SWR meter....it will help immensely
toshu is offline   Reply With Quote
Old 09-20-2020, 07:26 AM   #3
jenandjon's Avatar
The factory wire is only good for so long then you need to replace it. I just sent a couple radios to a shop to get peaked and tuned. If you have a good radio shop near by you are lucky. Go visit them. You can buy everything you need for coax and antennas at any truck stop. You can also upgrade the factory mic with a better one. I have had good luck with the fire stick antennas. They are cheap and work pretty good. Replace them every 3 years or so. I never had the money for the wilsons.
Father, grandfather, husband, farmer, trucker, mechanic, equipment operator, 03 Freightliner Columbia towing 06 Forest River Cardinal
Quando omni flunkus moritati-When all else fails, play dead
jenandjon is offline   Reply With Quote
Old 09-20-2020, 07:40 AM   #4
halla's Avatar
Ed, I ran a new solid line from a new Firestick antenna through the firewall up to the CB, used a SWR meter and it actually works. I think you are right, all of the breaks in the cable caused issues. It was not a problem getting the new cable through the firewall either.
2018 Dynamax Force HD BH---Just Rite-2
halla is online now   Reply With Quote
Old 09-20-2020, 08:01 AM   #5
SlowrideHD's Avatar
Folks still use cb's? For what?
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 09-20-2020, 08:04 AM   #6
Rick g's Avatar
CBís I use?
My question also. I didnt think they were in use anymore
Rick g is offline   Reply With Quote
Old 09-20-2020, 08:32 AM   #7
Chuck_S's Avatar
They aren't in use. At least my pricey Uniden scanner rarely picks up any traffic.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 09-20-2020, 09:12 AM   #8
Exactly what we did. Only used a local CB Shop. They couldnít get the original cable / antenna to tune.
Old 09-20-2020, 09:16 AM   #9
We donít on the highway. Use it frequently when someone is out on the ATV and we are not in cell range.
Old 09-20-2020, 09:24 AM   #10
Same here at our cabin when people are out hunting on property. (52 acres) but we quickly found out that Walkie Talkies were just as good and way cheaper.
TheWolfPaq82 is offline   Reply With Quote
Old 09-20-2020, 09:34 AM   #11
I found it useful once when jammed up in traffic on the I-40. The truckers had all the information to satisfy my curiosity.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2018 RZR XP 1000 Ride Command
rskeans is offline   Reply With Quote
Old 09-20-2020, 12:46 PM   #12
FOURWHL's Avatar
Listening to truckers gab like schoolgirls
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is online now   Reply With Quote
Old 09-20-2020, 01:43 PM   #13
No kidding. On long drives it can be entertaining. Seems to be more CB traffic in the south and southwest.
Old 09-21-2020, 03:14 PM   #14
duneviper's Avatar
Thanks for the information, I thought I was doing something wrong with the settings. I couldnt get mine to work on the first trip out.
duneviper is offline   Reply With Quote
Old 09-21-2020, 03:18 PM   #15
Freightliner has a very poor design on our M2s...
I've completed the installation on the driver side antenna. Working on Passenger now. Should have it done and tuned by next weekend and will report results.
Old 09-22-2020, 02:32 PM   #16
I actually just completed the installation of my GMRS radio. The Midland I installed in the motorhome is 40 watts on high. My toad has the 15 watt version. Have not had the opportunity to try them out yet.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 09-22-2020, 02:49 PM   #17
Motorized GM
Well, we solved this, we got rid of the CB.
For now, I have left it pre-wired and there is a cover plate.
But, I can add a little cubby for storage up there (losing the pre-wire), but I figured the spot was open if you wanted to add it. Now, I'm not sure having the pre-wire is worth it, if that is what was causing most of the problems.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
bclemens is online now   Reply With Quote
Old 09-22-2020, 03:40 PM   #18
KRedburn's Avatar
Forget the pre wire. Put a nice indoor outdoor weather console in with appropriate sensors on roof. 2 cents
Ken and Kathy Redburn
2018 DX3 37TS (The Taj)
KRedburn is offline   Reply With Quote
Old 09-22-2020, 03:42 PM   #19
MoJoe1003's Avatar
[QUOTE=bclemens;2419015]Well, we solved this, we got rid of the CB.
If you ever decide to do the cubby, Iíll be first in line to buy the insert... assuming it will retrofit.
Joe & Cynthia
2018 Dynaquest XL 3801 TS Cindy 'B'
2018 Jeep Wrangler Unlimited Sahara
ďBreathe in, Breathe out, Move onĒ
MoJoe1003 is offline   Reply With Quote
Old 09-22-2020, 03:52 PM   #20
Motorized GM
[QUOTE=MoJoe1003;2419045]
It is available from Freightliner already. I'm just waiting on a part number.
