Ceramic coated window tint - what a difference!
I just had window tint installed on the cab. My original plan was to install it on the driver and passenger side windows only...but,
After the mobile service owner and I started talking he was asking about what level of tint I wanted. I told him I was more interested in reducing the heat going into the cab. That's when he showed me the tint film options. The ceramic tint is more expensive but it reflects 99.9% of UV and hence the heat from going through the window into your cab.
Then he said he could also put it on the front window (primary source of heat) and showed me his truck with the product. I could not tell it anything was actually installed on his truck windshield.
So, I had limo put on the sides and clear put on the windshield. It doesn't matter what level of tint (none, light or dark) you have installed to reduce the heat build up since they all have the ceramic coating. The difference is amazing. Highly recommend it to anyone interested in reducing the heat build up and transfer into your coach.
Check it out with a local mobile service provider.
_____________________________
Sal & Teresa
2019 Dynaquest XL 37RB Midnight Sapphire
2019 Jeep Wrangler
USN Veteran (USS Saipan, VAQ-34)
