Old 12-31-2017, 03:04 PM   #1
hhl
Circuit breakers isata 3 24FW in coach battery compartment
My circuit breakers are not labeled. from left to right which ones are slide, levelers etc.
hhl is offline   Reply With Quote
Old 01-30-2018, 10:41 PM   #2
hhl
Checked circuit breakers today.
Left to right, circuit breakers for this unit.
1: 80 Amp 4 point leveling
2: 150 Amp inverter
3: 80 Amp converter
4: 150 Amps bcc panel
Old 02-01-2018, 07:43 PM   #3
xgarys's Avatar
2: 150 Amp inverter
3: 80 Amp converter
What is bcc?
xgarys is offline   Reply With Quote
Old 02-01-2018, 07:50 PM   #4
Rich.M's Avatar
Battery control center
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 02-01-2018, 07:55 PM   #5
xgarys's Avatar
Is that the charge input from the converter assembly then? Does that then mean that the "Converter" is for the output from the battery back to the assembly?
Old 02-01-2018, 08:07 PM   #6
Rich.M's Avatar
Here is a link on the bcc
http://www.precisioncircuitsinc.com/...R-BCC-RevC.pdf
Converter can charge the house batteries directly and charge coach batteries thru bcc, coach alternator can charge house bats driving thru bcc. Bats coach and house can be linked thru bcc for emergency start switch e.g. Start coach with dead coach bat or start genny with dead house bat.
Bcc also has protections aganst putting slides out while coach running.
2015 Solera 24r
2017 Jeep Wrangler
Old 02-02-2018, 09:26 AM   #7
Commercial Member
I had them label some stuff. I have not reviewed this...but hope it helps.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (Do Not Ask in a PM) so others can benefit from the answers.
Sales-Service-Parts https://dynamaxcorp.com/contact-us
battery, breaker
