sounds like smoke...we refer to compartment doors as exterior compartment doors and all of those are side hinge. I assume you mean over head cabinet doors???
On those we use hold open hinges. Those work or don't work a lot based on temperature. So the weight of the door might be too much when it gets warm. Just need to add a hinge or two and I'm 99% sure those are surface mounted hinges, so easy enough to add.
You could add a strut, but we find those to cause other issues...if its only one side, it tends to make the door crooked over time.
Email parts with your VIN and contact info to see about some extra hold open hinges. The other option are those little struts on either side.
https://www.amazon.com/RV-Designer-H.../dp/B003VAT8KE (these we don't carry)
