Old 07-12-2020, 10:02 AM   #1
Oldnapapartsguy's Avatar
Converting isata 4 to lithium
I want to thank all that have posted their experience with changing to lithium batteries. I finally got brave and tackled it. I was amazed at how easy it really was to accomplish. I think the hardest was converting the BCC to the Li-Bim225
The Progressive Dynamics Lithium conversion was super easy and took maybe 20 minutes. I decided to go with Lion Energy lithium batteries for a couple reasons. First they make a 105 ah battery in the group 24 size which gave some room to install the Victron Smart Shunt. (By the way these are available now in a limited number so if you want it better get it ordered) Just do a search, bought mine from Inverters-R-US. Second the Lion batteries come with a lifetime warranty and Costco had a deal, 2 for $1399. I have been running tests, including slide operation and I couldn't be happier. Slides work so much better with the increased voltage and with the coach plugged in the voltage stays around 14 volts while operating. I had a Go Power solar controller which already had the lithium setting so just had to change that and watch it work. Pulled out in the sun and the solar worked better than ever. I am so excited to get camping soon to try all this out. Heading to the Smoky Mountains at the end of the month.
ID:	233745   Click image for larger version
ID:	233746   Click image for larger version
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
Oldnapapartsguy is online now   Reply With Quote
Old 07-12-2020, 06:22 PM   #2
Motorized GM
That is awesome! The higher voltage is definately a win-win. We say to run the engine to get the highest voltage (motors just run better), but with Lithium that seems to work just as well.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 07-12-2020, 07:58 PM   #3
Being plugged in or generator running works just as well as running the engine, never used to be that way. I always started the vehicle and waited till it hooked up through the BCC center. This makes it easy to pack up and move on. Thanks Brian for all your support. All the posts encouraged me to move forward. Any one wanting to make a big improvement, LITHIUM with the correct charger.
Old 07-12-2020, 09:23 PM   #4
I'm adding the SmartShunt to a Isata 3. The battery connect posts on the shunt are 10mm (a bit bigger than 3/8") but the ends on the existing cables are 5/16". Easy to replace short cable from battery to shunt but I'm not sure yet how I'm going to connect to the existing cables.
NearDenver is offline   Reply With Quote
Old 07-12-2020, 09:45 PM   #5
mlmay12's Avatar
Nice job, looks very clean. Just got back from Utah and it is really nice not to worry about having power. Mine seldom goes below 75% and I use lots of power. I exclusively boondock. My solar could work better, even with 400W of panels in full sun I only get about 10A. They are 4.5 years old so that may be why. I haven't worried about it as this tops my batteries off every morning. I have had my Lithium system for over 2 years now and couldn't be happier.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Buddy, Mr. Jake (RIP), Casey Girl (RIP)
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 07-12-2020, 11:54 PM   #6
jneum525's Avatar
What was the weight savings in switching to the lithium batteries?
jneum525 is offline   Reply With Quote
Old 07-13-2020, 05:50 AM   #7
Might see if the cable ends are heavy duty enough to enlarge. I have done this many times by using a round file to make it large enough. Another option is to call an auto parts store, they might have a crimper to replace the cable end. As you can see by my screen name I am partial to NAPA Auto parts 😂
Bill & Sue
Old 07-13-2020, 05:56 AM   #8
Thank you!
Canít wait to try this set up. I pulled mine out yesterday and the factory 200 watts of flexible panels were putting out just short of 11 amps. I did clean them with some headlight polish a couple months ago. What amazes me is how fast the lithiumís charge back to full.
Bill & Sue
Old 07-13-2020, 06:16 AM   #9
The Lion Energy lithium batteries only weigh 23# so I had a total savings of 92# after dragging the group 31 AGM deep cycles out. Not bad, can't hurt.
Bill & Sue
Old 07-13-2020, 06:20 AM   #10
A BattleBorn 100aH battery weighs about 29 pounds. A typical AGM battery will be in the 75 pound range.
Riverbend is online now   Reply With Quote
Old 07-13-2020, 12:48 PM   #11
Check Amazon. They have cables with 5/16 on one end, 3/8 on the other. Buy a short one and shrink wrap the connection.
boogiejack75 is offline   Reply With Quote
Old 07-13-2020, 01:32 PM   #12
Or just order the exact length and ends you need.
https://www.genuinedealz.com/custom-...cable-assembly
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 07-13-2020, 02:10 PM   #13
That too!
Old 07-13-2020, 02:17 PM   #14
Most are. Going from 5/16" to 10 mm only requires removing a little more than 1 mm of material total. That's 1 mm off the radius and 2 mm off diameter. Most cable terminals have more than enough "meat" to go one size larger.
On some connectors I been known to "clip" one end with a pair of diagonal cutters and open up the ID with a tapered punch much like a goldsmith would resize a ring (only no real need to fill in the gap). Install connector, top with a washer, and clamp tight with the nut.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-13-2020, 07:36 PM   #15
I think this is my current plan.
Old 07-14-2020, 06:30 PM   #16
WORKS!!
Bill & Sue
