06-13-2021, 08:49 PM
Crack in fiberglass roof
Apologize for the duplicate post...wasn't sure if it got lost in the other thread. Last weekend we had water coming in from the ceiling (and even showing up in one of the storage bays) on the passenger side. Noticeable after a rain, but also somewhat noticeable when the rear A/C was running. Finally got a chance to get up on the roof and found it cracked around the center mounting bracket of the rear false awning on the passenger side. I'll inspect all the other areas while I'm up there, but, fortunately, this is exactly where you would have thought it was coming in.
Can I simply clean that area really well and cover it all with a new coat of dicor and/or dicor sealing tape, or do I need to address the cracks with something else prior to coating with dicor? Drill holes at the end of the cracks to try to prevent further cracking?
Thanks!
JT
2018 DX3 37BH
06-14-2021, 06:29 AM
I believe what I would do is repair the area with fiberglass patch about 2 times the size of the area after stop drilling to reinforce the area and then paint and cover with sealing tape and self leveling dicor. Looks like it cracked due to stress. JMHO
Retired Navy
2016 Flagstaff 26 FKWS
06-14-2021, 02:46 PM
It appears to be cracked below the dicor along the leading edge of the bracket as well. It almost seems like if you wanted to patch it with fiberglass the bracket needs to be removed, then the whole area needs to be patched, and then the bracket would be reattached on top of the patched area.
It's definitely a stress crack, but I wouldn't think this is 'structural'. As such not sure if a full fiberglass patch is necessary or not.
Thoughts?
2018 DX3 37BH
06-14-2021, 03:56 PM
Thoughts?
As a former boat owner, fiberglass repair is common, and the best way to have a lasting repair. Adhesives are temporary at best.
The bracket needs to come up anyway. The crack goes right along the front of the bracket, so maybe the angle of the bracket started the crack.
And it is "structural" in a sense, in that the fiberglass is carrying the weight of that bracket and everything mounted to it.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
06-15-2021, 03:23 PM
X-2. Good answer and the right repair considering that the bracket is relying on that area for support.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
06-15-2021, 05:15 PM
Wifey call me for dinner. Shouldn't you find the reason for the crack before patching?
Just saying.
06-15-2021, 05:24 PM
Pretty sure the false awning came in contact with a limb or something and inward leverage on that bracket caused the crack...especially considering the crack along the leading edge of the bracket beneath the dicor.
I'm all for patching it correctly with fiberglass. I guess at this point I'm most concerned about what's below the single bolt (lag bold I'm assuming) that's holding the bracket down. Is there wood under the fiberglass that this bolt is threading into, or is it part of the underlying roof structure? If it's part of the structure, how critical is it that the bolt go back into the same place after the patch? Also, regardless of what it's bolted to, I'm curious why it would give enough to cause the crack to begin with.
2018 DX3 37BH
06-17-2021, 12:14 PM
There is wood under it, I know this from fixing mine. But the wood will not hold a screw well since water got in there. So add some screws nearby in addition to hold it.
06-17-2021, 01:02 PM
Did yours crack too? If so, did you patch it with fiberglass?
2018 DX3 37BH
