05-21-2021, 06:05 AM
Norwood Auto Italia
DEF Consumption?
Just finished a 2500 mile trip and was surprised to find that DEF "range" was about that amount. I used a 1/2 tank for about 1300 miles per the gauge and augmented the tank with a 2.5 gallon box purchase and a frustrated purchase at a truck stop.
Wonder what others are seeing? My 2014, Ford F550 6.7 PSD Born Free of a similar weight to the 28SS saw about twice the range from a 7 gallon tank vs the RAM 9 gallon capacity.
I have to find the exact stopping point for a truck stop hose to reach both the gas tank and the DEF tank. There is a point I suspect that works for both but I have yet to find it.
Then there is back and forth to the cashier and the overcharge if a second CC swipe is needed for DEF. Not sure how to avoid that without an extended stop to the amusement of the 18 wheeler stacked behind. I never used the truck fill DEF with the F550 because it used so little.
2000 Sportsmobile E350 EB
2006 Renegade/Peterbilt K1854 and T1220
2021 Isata 5 28SS Explorer
05-21-2021, 06:52 AM
I have the TSD rv card, lets me fuel and use def in the truck lanes, plus we get a discount. So far I have not had issues filling fuel and def.
Range, I dont really gauge it but your summary seems close to what I use.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-21-2021, 11:23 AM
The DEF gauge in my 2019 Isata 5 36DS is definitely not linear. Adding 5 gal of DEF brings the gauge from the “low” mark to dead on the full mark. The tank will then easily take 2+ gallons to fill completely. I now average between 300 and 350 miles per gallon of DEF, depending on how much idling / stop and go traffic. When new, it barely got 250 miles on a gallon. I don’t like to keep too much DEF in the tank as I may go 3 to 4 months without driving it. The process to remove old DEF from the tank is a pain!
Phil and Jan
2018 Isata 5 36DS 4x4
2021 Jeep JL Rubicon
05-21-2021, 02:42 PM
Norwood Auto Italia
The owners manual for the RAM C&C is quite specific about the gauge not reading a linear capacity which they define as a "reserve" over the indicated FULL amount.
Interesting that your consumption rate has improved - I will look for that as I get past my current 5K.
I never had any issues with DEF use in the F550 despite a much slower rate of consumption that resulted in barely one 7 gallon tank usage a year for 12,000 miles. With frequent 2 day journeys of 1200+ miles, I guess I wont have an aging problem.
05-21-2021, 02:59 PM
2018 1 ton DRW Chevy pull 14k, Ohio to Colorado (Silverton) and return, 1 gal per 400 miles, using cruise majority of the time. Definitley concerning. Later found on line others getting similar consumption.
2018 Forest River Wolf Pack 315Pack12 Toy Hauler
2018 Chevrolet 3500 LTZ
Goosebox, MORryde 4 step with hand rail
Sailun S637 ST235/80R-16
05-22-2021, 08:46 AM
I get about 280 DEF MPG tracking this 5 times so far. Like hella said, I have a EFS card which allows fueling at the truck stops without going in and prepaying. Additionally, you get a discount on fuel. The discount and convenience is well worth the application process. You have to fuel first and than add DEF. I have my wife back up a little so the DEF hose will reach.
2021 Isata 5, 34DS
Colorado
05-22-2021, 09:06 AM
Brake is on left
Across all manufacturers, the dose rate for DEF is an average of 2% of the fuel consumed. Some more, some less. So for every 50 gal of diesel you can assume 1 gallon of DEF was used.
05-22-2021, 12:17 PM
Here is what the Cummins Website says about DEF consumption which confirms the 2% of fuel consumed guideline but it does say the loading on the chassis is a factor. Since most of us run close to the 19,500 lbs and also pull a vehicle, we probably put more load on the Cummins than say a RAM 3500 pickup.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
05-22-2021, 02:22 PM
Norwood Auto Italia
Thanks Milkman55 for that - confirms my observations which as I wrote, about 2X the Ford F550. My guess is that the Cummins is a a higher state of tune than the Ford, using higher boost and demanding more "cleaning". Road and weather conditions about the same but over 60,000 miles in the Ford I had plenty of opportunities to measure and observe.
