09-25-2020, 08:16 PM
#41
jkoenig24
Walmart has their "Super Tech" brand in a 2.5 gallon blue poly jug for ~ $8. I've used it many times over the years and have never had a problem. As already mentioned, as long as it meets or exceeds SAE & API standards, you're good to go. Also as mentioned; Bulk DEF purchased at a truck stop diesel pump at a will be less expensive than the "bottled" product.
09-25-2020, 08:21 PM
#42
The bad thing about the Walmart brand is the seals don't seal well. Almost every jug of it is caked with crystalized DEF from one leaking. And when you check the seal on the jug, half the time they're not attached.
But at least the date is easy to read.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
09-25-2020, 08:22 PM
#43
My 2014 Chevy Duramax defiantly has a heater in the DEF tank. It failed twice and dealer replaced tank both times. Third time the sensor went bad and again dealer replaced the whole tank. All this was covered under Chevy warranty as they apparently had a bad batch of heaters and sensors in the 2013-2015 years. Warranty was 5 years or 100,000 miles. Sadly I’m past the five years.
Charlie & Cindy
2022 Duramax 3500 cc sb
2017 Wildcat 32 WB
09-25-2020, 08:24 PM
#44
But does it heat when the truck is sitting outside overnight? Even when plugged in, my Ram doesn't heat the DEF tank.
2018 Ram 2500 CTD
09-25-2020, 08:38 PM
#45
Originally Posted by medalguy
Screw around at a truck stop? I pull in, fuel up, and add DEF when needed. Couldn't be simpler and I don't have to worry about the box nozzle fitting snugly so I don't drip DEF all over the compartment, and it's cheaper.
Ditto what you said about using truck stops. I was apprehensive at first, but both fueling and DEF filling are simple and quick...quicker than at the automobile pumps...and it's soooo much easier getting my rig through those truck lanes.
09-25-2020, 08:45 PM
#46
Only heats when my truck is running.
Charlie & Cindy
2017 Wildcat 32 WB
09-25-2020, 11:14 PM
#47
Age and contamination are the two big issues with DEF. Other than that, DEF is DEF regardless of packaging. Clean and fresh is key.
Terry and Laurie
2017 Flagstaff 27RLWS
2020 F-350 7.3 Godzilla 10 speed 4X4 CCLB
09-26-2020, 10:08 AM
#48
DEF age
09-27-2020, 03:33 AM
#49
Originally Posted by milkman55
I use the Blue DEF box because I don’t go to truck stops. I can go 800 miles on a 2.5 gal box and I add one box every other day of traveling. I just got 2 boxes for $24 at Tractor Supply on sale. I am sure I could save money, but my convenience is more important to me.
Are you sure about that? I get almost 10,000 miles out of 7.5 gallons in my 3/4 ton truck.
09-27-2020, 05:48 AM
#50
DEF is easy, Walmart when needle hits 1/2 add one 2 1/2 gallon right there Walmart lot. Never seen broken seal or bad date, I always check.
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
09-27-2020, 06:25 AM
#51
"On the road again"
Originally Posted by rskeans
Walmart price ends up at $3.20/gal It's easier for me to pay that than go screw around at a truck stop. JMHO.
We buy most of our diesel fuel at Petro and get the great discount from our TSD fleet card - so it's no problem to add DEF while we're there at the pump anyway.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
09-27-2020, 07:45 AM
#52
Originally Posted by eaglecrest
I've been told that Ford and Ram are the best DEF - that's independent service people advise. I get Ford DEF at my local Ford dealer for $24.75 that's 5 gallons(comes in a case of 2 2.5 gal containers). My son uses Blue DEF and he just spent $3400 on getting his system fixed and they told him to use either Ford or RAM DEF. I'm not saying one is better than the others - just what service people told me.
I’ve been using Blue DEF in 2 Chevy trucks at just over 130,000 miles with no problem with DEF system. I always make sure the seals are good, and yes I have found broken/missing seals.
Brandi
09-27-2020, 10:37 AM
#53
Originally Posted by TrailWayz
Just wondering if there is any difference in the quality of DEF fluids between brands.
Here's my experience. I have a 2018 GMC 3500hd Duramax. Bought it new. It now has 54,000 miles. I can say 99% of the time I buy Walmart brand DEF. (2.5 gallons for $7) It has always run fine with that. The only time I didn't buy Walmart is because they were too far away for my poor timing.
I know that when I get a warning that I'm down to 29-30%, I can add 5 gallons of DEF. I just carry two jugs, 5 gallons, in the back of the truck when I'm towing.
Just my 2¢
09-27-2020, 06:16 PM
#54
Check out BlueFire j1939 adapter. It allows you to monitor all kind of chassis data including DEF quality and temp. Great device and great support.
09-27-2020, 07:10 PM
#55
Originally Posted by TRN
I get my DEF where I get my fuel, at truck stops. Easy and no mess.
Same here.
09-27-2020, 08:28 PM
#56
Olemax
DEF Heater and Shelf Life
DEF freezes and thaws with no harm. The GM Trucks (and assume others) have a small heater to thaw a small quantity for use by the system, during very cold periods. tNo harm leaving the tank full over winter.
Summer is another, more serious matter.
DEF deteriorates at temperatures above 75 F. The higher the temperature, the shorter the life. This is a lesson I learned the hard way. (It costs $1,000 or more to remove the tank and replace the pump and injector.) See this article from a supplier https://www.peakhd.com/lifeblood/flu...contamination/
Since one cannot tell how DEF was stored before purchase, so best bet is to buy from a supplier that sells a lot and keeps a fresh supply. Check date on the container to be sure it isn't over 12 months old, to be on the safe side.
Olemax - NW NC
2011 Sabre RETS
2012 Silverado 3500HD CC LB
2006 Sierra 2500HD CC SB (sold)
09-28-2020, 05:16 AM
#57
Interesting gadget, I'll have to look into that. Thanks for posting it.
09-28-2020, 05:25 AM
#58
I used to have a ScanGauge D and switched to the BlueFire about 6 months ago. I love it. Very easy to read and customizable with a lot of great information all on one screen.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
09-28-2020, 08:59 AM
#59
Originally Posted by hankpac
It is Urea. Period. How much quality does one need for Urea?
It is sprayed into the exhaust, ahead of the Catalyst (SCR). Doesn't go into the engine.
Sole purpose is to reduce COx.
So, quality is a non-issue. Buy the cheap stuff.
Typo?
From Wikipedia: https://en.wikipedia.org/wiki/Diesel_exhaust_fluid
" ... used to reduce the amount of NOx released into the atmosphere."
09-30-2020, 06:48 AM
#60
"I get my DEF where I get my fuel, at truck stops. Easy and no mess."
To save money do not fill diesel at a truck stop.
Sure its great when we had a bus conversion and could fill from both sides to get 150 gallons.
The dinky diesel nozzle was a PIA
But now with a Sprinter we only take 20 gal or so and the frequent dime a gallon cheaper at the car diesel pumps eventually buys dinner out.
