Old 09-25-2020, 01:57 PM   #21
My 2017 3500 Sierra Dually has a 7 Gal DEF tank. I keep a spreadsheet and calculate my MPG for DEF usage. I use my truck to haul my signature 5ver and then to sight see....otherwise, it sits in my garage.
I'm getting about 440 miles per gallon of DEF for my situation.
I try to drive my truck just a little during the winter, just to use some of the DEF that sits in the tank. I do worry when it sits for long periods of time.
Mike K
2019 Cedar Creek 34RL2 w/disc brakes
2017 GMC 3500 D/A, DRW, 40Gal Aux Tank
USN 76-82
Retired Dept of Navy: Navy/USMC Flt Test Engineer
Splashes3 is offline   Reply With Quote
Old 09-25-2020, 01:58 PM   #22
Retired Member
RMWSierra's Avatar
Originally Posted by Chazman View Post
I'm curious.. My new (to me) 2018 Sierra supposedly has about a 5 gal DEF tank. We bought the truck in March of this year, I have put about 4k miles on it, and my indicator still says "DEF fluid level ok". Do some diesels use that much more DEF fluid than others? I too have wondered about the quality of different brands as I'm guessing I will need some soon.
My Ram DEF level gauge doesn't start indicating off full until first 1/4-1/3 is used. Bad design
RMWSierra is offline   Reply With Quote
Old 09-25-2020, 02:01 PM   #23
B and B's Avatar
Originally Posted by milkman55 View Post
I use the Blue DEF box because I don’t go to truck stops. I can go 800 miles on a 2.5 gal box and I add one box every other day of traveling. I just got 2 boxes for $24 at Tractor Supply on sale. I am sure I could save money, but my convenience is more important to me.
That usage seems high to me.
Old 09-25-2020, 02:01 PM   #24
I forgot to mention, I use the Walmart DEF for the most part....unless they are out.
Mike K
USN 76-82
Old 09-25-2020, 02:44 PM   #25
Chazman, I own a 2015 Chevrolet 2500HD that has a 5 1/2 gal. DEF tank. If not towing I get a 1000 miles per gallon of DEF, if towing our 5th wheel camper then the miles are much less. Your OK light or indicator will not come on until you get down to around one gallon remaining. On my Chevy, it will tell me how many miles I have remaining until the truck goes into the limp mode.
Walholler is offline   Reply With Quote
Old 09-25-2020, 02:51 PM   #26
D W
D W's Avatar
I myself don't use DEF, but the Walmart brand (SUPERTECH), seems to be a hot seller. At any given time, you can go to any of the 3 Walmarts in Anchorage and find trash cans as well as shopping carts full of the empty containers in the parking lots. I've also witnessed the same at the Walmarts in Wasilla and Fairbanks. Must be OK stuff.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 09-25-2020, 03:07 PM   #27
Good to know!
Good to know, thanks for the info! BTW, I'm amazed at the highway mileage I get with this truck. Heading back to RI from NH I was getting 27 mpg doing 65 - 70.
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
Chazman is offline   Reply With Quote
Old 09-25-2020, 03:33 PM   #28
Alpha Wolf 29DQ-L
Originally Posted by TrailWayz View Post
Curious, how do you prevent from overfilling the DEF at truck stops?
The DEF nozzle kicks off just like the fuel nozzle.
Jcrow9 is offline   Reply With Quote
Old 09-25-2020, 03:37 PM   #29
Paul & Dianne
This. When not towing, the gauge never seems to change. Towing, it does. I’ve been using the cheap Walmart Supertech DEF since we bought the truck, without problem. The one time, towing, where low DEF and low diesel coincided, I pulled up to the truck pumps at a Love’s I think it was. Went in to get the diesel turned on and said I needed DEF too. The girl said, “Oh, we just had those put in, they’re not turning them on until next week sometime.” 😦 So, I wound up buying 2-1/2 gal of whatever they had there in the store for $16 or something outrageous like that. Diesel price was great though! 😄
2019 Rockwood 8299BS
2019 F350 Lariat 6.7 CC SRW
ThruHiker is offline   Reply With Quote
Old 09-25-2020, 04:16 PM   #30
5er_tom's Avatar
I read somewhere that DEF shelf life is 2 years.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
5er_tom is offline   Reply With Quote
Old 09-25-2020, 04:21 PM   #31
5er_tom's Avatar
DEF, is there really any difference in quality?
Just purchased two 2.5 gallon jugs of Blue, for $9.99 each at Fred Meyer gas station.
Got it at the pump island. Did not have to get out of the truck. Here in Oregon they only have full service. The attendant put the 2 DEF’s in the truck bed while filling the diesel truck. Can’t get easier than that.
Tom & Renée
Durham, NC
Old 09-25-2020, 05:13 PM   #32
More good info
Thanks, this is more good info for me. I didn't mean to hijack the thread, but this is my first diesel and I'm still learning.
Old 09-25-2020, 05:21 PM   #33
I've been told that Ford and Ram are the best DEF - that's independent service people advise. I get Ford DEF at my local Ford dealer for $24.75 that's 5 gallons(comes in a case of 2 2.5 gal containers). My son uses Blue DEF and he just spent $3400 on getting his system fixed and they told him to use either Ford or RAM DEF. I'm not saying one is better than the others - just what service people told me.
eaglecrest is offline   Reply With Quote
Old 09-25-2020, 06:16 PM   #34
MoJoe1003's Avatar
Originally Posted by dwilli1 View Post
Hey TRN, will the truckstop pump nozzles fit a GMC 2500? Or do they have smaller nozzles at a pump alongside them? I always thought those nozzles are too large for standard pickups. I've only had my pu a month, filled DEF from BlueDEF 2.5 gal box.
DEF nozzles are all the same. They will fit in your GMC 2500. Diesel fuel nozzles are usually bigger than gasoline nozzles. However, that is not always the case. Had a friend who was riding with me on an 1800 mile motorcycle trip manage to fill his Harley with diesel fuel! It was an Amoco station and their diesel pumps had yellow handle covers instead of green and the nozzle fit his tank. Not one of our better travel days!
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 09-25-2020, 06:36 PM   #35
Brake is on left
The Evil Twin's Avatar
I think I said this in another DEF thread- its just water and cat urine, not rocket surgery. As long as it meets the requirements set forth by ISO for purity, burn it. I have shy of 55k and my neighbor is approaching 200k on $8/ 2.5 gallon jugs from Tractor Supply and Southern States. Not one emission related repair.
I do get it at the pumps when travelling just because it is right there at the tractor trailer pumps. A bonus is both the fuel and the DEF is cheaper there. Too easy not to top it up there.
The Evil Twin is offline   Reply With Quote
Old 09-25-2020, 06:41 PM   #36
FOURWHL's Avatar
This is starting to feel like a tire pressure thread
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 09-25-2020, 07:02 PM   #37
Vince and Charlette's Avatar
Here's the site from Sinopec who makes DEF: https://buysinopec.com/blogs/news/ho...ust-fluid-last. They, along with two other sites I checked, say max shelf life is two years depending on temperature and a few other things. DEF freezes at approximately 12 degrees F, but manufacturers have done things that lower the freezing temp. (See package for details.) Personally, although we always fill up at truck stops, I don't keep my backup emergency jug much longer than a year.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 09-25-2020, 07:04 PM   #38
Brake is on left
Old 09-25-2020, 07:42 PM   #39
PhoneDude 8289's Avatar
Peak Blue has a new one out "Peak Blue platinum" at almost twice the price. I don't see anything special about it, just two ingredients, urea and water.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-25-2020, 08:01 PM   #40
IchLiebeBier's Avatar
Shelf life in a store is much longer than when you put it in your tank, depending on temperature, of course.
I personally only fill it up half-way, since I don't currently tow enough to use it up very quickly. I've read that it will go bad more quickly than I'd use it if I fill it up.
Also, since the DEF tank itself isn't heated overnight, I like to give it expansion room in case of a hard freeze. Something to think about.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is offline   Reply With Quote
quality
