07-10-2017, 12:07 PM
Dinette Height - Isata5 - adjustments ?
Do any Isata 5 owners notice the Dinette height being on the low side ?
It almost touches the top of my thighs when I sit and I'm only 5'7 185 lbs
when you exit your thighs get wedged. Not good
I don't know what the installer was thinking when he mounted this thing But if this is the height he decided on he is either a very thin person or out of his mind
Is there an adjustment ? Or will the whole mount have to be taken off and raised.
Anyone see this as well ?
Regards
07-10-2017, 01:06 PM
In 6'1 and don't have that issue. Still 3 inches from my leg to the bottom of the table.
The table does lower to make into a bed. Did you check your table is all the way up?
Pat
2017 Isata 5
07-10-2017, 01:12 PM
Commercial Member
Man oh man, where to start.
On our M2 trucks the dinettes used to sit too high. As we dug into this we found out the standard "Dream Dinette" is designed to sit at 29-30" above where your feet would sit (from floor to top of table). The problem is, we had a wire chase along the outside wall that was about 2-3" tall. That means the dinette sat too high by 2-3".
So, we started getting a new "Dream Dinette" that is designed just for this case and sits 29-30" above the floor when installed on top of a wire chase that is 2-3" off the floor.
Well, the 5 series doesn't have a wire chase like the M2 trucks did and they probably just installed it right where the floor meets the wall instead or pretending there was a 2-3" wire chase in the way, raising the whole thing up.
So to make a long story longer...the table needs to move up about 2", it is not adjustable. We are ware of this and caught all of them we found...but some may have gotten out.
07-10-2017, 01:24 PM
Interesting. The table in mine is installed where the floor meets the wall. Haven't had the knee bump problem but it does making sitting down and getting out a little tight. May move it up. Thanks.
Pat
2017 Isata 5
07-10-2017, 01:27 PM
Commercial Member
Plenty of back there, so shouldn't be an issue.
Just make sure you maintain proper height (not a custom height, or it might not make into a bed properly). It is designed like a normal table to sit 29-30" off the floor to top of table.
07-10-2017, 01:33 PM
Heh I was going to say I have the exact opposite problem! Going down was simpler than up though. Then again I guess re-mounting it is not that big of a deal.
2016 Dynamax DX3 - Big Blue
07-10-2017, 01:45 PM
Bill
That's what it is 2" would be right at the right height. So.. who would do this mod ?
Warranty work ?
07-10-2017, 02:01 PM
Commercial Member
Well, you can schedule a service visit, have the dealer raise the table, it would be considered a warranty item., especially if you have any other things that need to be addressed.
Or if you're handy, It basically cantilevers out from the wall, so its just a matter of pulling the screws that go into the wall on both sides of the vertical bracket. Lifting it up 2" and reinstalling. It all depends on how frustrating the current situation is and how far out dealers are for service.
If you were so inclined to do the work and save the dealer visit, while we don't pay for stuff like that we try and pay it forward in future favors I might be able to get you one of the new flash drives when they come in. (But don't tell FOURWHL, because I know he loves Blue and these things aren't cheap so he'll make up some warranty issue and try to get the same deal, but he's already wrecked his and this is why he can't have nice things)
07-10-2017, 02:13 PM
Ahhhhhhhhhhh you're killing me over here!! It's ok I need to sweet talk you into a new skylight first
Though those are badass and I need one.
07-10-2017, 02:21 PM
Commercial Member
They are pretty cool. I want one myself. I already know I will have to put them under lock and key.
I ordered them for our dealer expo (wholesale only) in lieu of stuffing a bunch of folders with brochures and flyers. I may use these to ship with the manuals once we run out of the plain logo'd one.
07-10-2017, 03:07 PM
Right On ! LoL . Ill check it out
07-10-2017, 08:25 PM
Moved table up 1 1/2 inches. The hardest part was figuring out how to support the end of the table as it was removed from the wall and moved up. Otherwise was easy.
Pat
2017 Isata 5
07-11-2017, 08:25 AM
What did you end up using to support it ? cut to length 2x4 or stacked boxes ? Hopefully Ill have a 2nd person. Right on
07-11-2017, 04:36 PM
Well, I used two woodworking clamps at the end of the table that where close to the height needed. When I raised the table I put wood blocks underneath to shim up to the new height. Worked well enough.
Pat
2017 Isata 5
07-11-2017, 06:21 PM
Does the flash drive have the shoe storage? Lol.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
07-12-2017, 08:06 AM
Commercial Member
crap...I'm going to have to have new ones molded now.
I wish Dynamax would stop making changes that make me want new anatomically correct flash drives.
07-12-2017, 08:42 AM
I would pay for the flash drive to use at work, how many other colors did you get?
07-12-2017, 09:39 AM
Commercial Member
Just the blue. I'll ask and see what other colors might cost.
