Originally Posted by Coda
Just picked up the Isata 5 from the factory. The window is rattling and even has air coming in the bottom. The glass seems to be rattling against the interior frame. This is probably because the factory had to remove the complete slide a couple of times during the repair. My question is this safe ore is there a risk of it working loose and falling out?
Removing the slide doesn't have much to do with the window...we normally pull the whole thing intact, no reason to pull the window.
The window should not be rattling. While some have in the past, they were not the fixed pane. The fixed pane shouldn't be moving...make sure you don't have a window open...that causes pressure build inside if there is not a way for the air to escape.
