Old 09-08-2020, 07:39 PM   #1
Dometic Refrigerator Suddenly Stopped Working
On the way home from 10 days at the Grand Canyon, the refrigerator shut off (2018 Isata3 Dometic). Had full hookup at the campground and was fine. Running on propane during the trip home when it shut off (died at about hour 7). There are no lights at all. At home, checked the fuses outside and in the panel and all good. Any suggestions for next step?
akkw is offline   Reply With Quote
Old 09-09-2020, 07:48 AM   #2
Bill Davis's Avatar
If it was very hot when it stopped it probably blew the the thermal fuse located inside the wiring harness. If you look at the wiring schematic on the fridge thatís outside under the cover you will see that fuse. Itís hard wired in. You can get the fuses on Amazon.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Bill Davis is online now   Reply With Quote
Old 09-09-2020, 01:36 PM   #3
Thanks! Checked the fuse with a multi meter and it is OK. Appears to be power everywhere it should be but still won't work. Maybe bad control board? Will try to contact Dometic.
Old 09-09-2020, 01:51 PM   #4
bubbles's Avatar
Does the fridge still work on shore/genny power (AC volts) because I think DC volts is still required.
Old 09-09-2020, 01:56 PM   #5
Just Tryin' to Help
cboss's Avatar
The thermal fuse looks like this. It is sometimes hard to find. Ours was way in the back in a wire sheath.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 846
cboss is online now   Reply With Quote
Old 09-09-2020, 02:21 PM   #6
Found the fuse in a sheath but checked out OK. Fridge doesn't work on generator power either. Unfortunately not in a place where I can plug into shore power. Assume since it doesn't work on generator it would be the same.
Old 09-10-2020, 01:11 PM   #7
Fridge
Check battery and turn off fridge for ten minutes at the thermostat in fridge. After ten min turn the thermostat back on. I have had this issue with my TT after being unplugged but definitely needs battery power. Mine seems to have an issue restarting with weak battery like itís trying to hard start against the back pressure fro trying to start!.
Scubabear32 is offline   Reply With Quote
Old 09-10-2020, 01:19 PM   #8
bubbles's Avatar
The fuses you checked are on the fridge circuit board, (1 AC and 1 DC fuse) correct?
Old 09-10-2020, 05:01 PM   #9
Finally got through to Customer Support at Dometic (2 hours on hold!). After I explained that I checked the fuses he said that it sounded like I needed to bring it to a dealer. Don't know about anywhere else but here in SoCal, I might be able to get an appointment in a few months! The tech had me check the voltage going to the upper board (the panel to turn it on and off inside). Since there was no reading , he indicated that the lower board is bad (one in the outside vent). I checked the test points and a 5 volt pin and didn't get any readings so I guess he is correct. Now I have to find a new board! Amazon doesn't appear to have it and another place is out of stock. Tried a couple RV dealers/repair and no luck. Any ideas?
Old 09-10-2020, 06:38 PM   #10
su
Dyer's RV in Phoenix has a large assortment of boards. They are an excellent dealership. https://www.dyersonline.com/featured...list_limit=all
l001952119 is offline   Reply With Quote
Old 09-10-2020, 08:37 PM   #11
I had the same issue in Anaheim and it was the thermal fuse pictured in post 5. Are you sure it isn't blown? If so they are available on Amazon, 10 for $8. Are give me a PM if you are in the area and I will give you a couple.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 09-10-2020, 08:49 PM   #12
Buy the Dinasour board for it.
babock is offline   Reply With Quote
Old 09-11-2020, 07:48 AM   #13
I checked the voltage across the fuse and getting the same as the battery so seems to be OK. There doesn't appear to be any voltage coming off the board so I think it is the problem. I'm thinking I will pick up some of these odd fuses just in case it is the problem in the future. Now just have to get in the queue again with Dometic to confirm the correct part number for the board!
Old 09-11-2020, 08:05 AM   #14
KyDan's Avatar
If you are buying the board- not in warranty- I would get the aftermarket replacement from Dinosaur Electronics.
They are well respected and give excellent customer service.
https://www.dinosaurelectronics.com/Dom_boards.htm
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 09-11-2020, 11:51 AM   #15
Even if I was in warranty, I would buy this board. Not worth the time and effort bringing an rv to a dealer for something like this.
Old 09-15-2020, 04:48 PM   #16
Quick update. Checked with Dinosaur Electronics and they don't have a replacement board. Called around to several dealers and found one that may have a board in 4 weeks. Called Dometic and they don't have any but will contact me when they are back in stock. Now I wait! Frustrating but I guess sign of the times.
Old 09-16-2020, 08:00 AM   #17
KyDan's Avatar
Wow, that stinks.
I'm surprised that Dino elec couldn't help. Must be too new?
Thanks for the update.
Good luck. Keep us posted!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-16-2020, 08:53 AM   #18
Motorized GM
I'll check to see if we have any in stock.
Edit: nope
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-16-2020, 09:14 AM   #19
yetavon's Avatar
Welcome to the Dometic not working club....
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 09-16-2020, 09:19 AM   #20
glsimms's Avatar
Hello Norcold????
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
glsimms is offline   Reply With Quote
refrigerator
