Old 09-07-2020, 03:19 PM   #21
Freshwater tank.
Hmmm. I installed an access port exactly like the one in the picture. So far, 🤔🤔,
I have had an immaculate water tank, 5.5 years after purchase new, with no screens over the vent or overflow pipe. The access port allows me to remove,with a wet/dry shop vac on wet, any remaining water if I am going to be on city water for a long time. I then spray the inside of the tank with Clorox Cleanup, hose it down with city water to rinse then wipe the entire inside of the tank with a sterile towel and leave it. I used a water test kit once just to check water quality after the above and after filling the tank 3/4. Results were excellent and drinkable.
As said previously, perhaps there is another issue?
Jim
2015 Dynamax Force 37BH
Jetjockey6 is offline   Reply With Quote
Old 09-07-2020, 03:40 PM   #22
Old Engineer
FleckDreher's Avatar
1) A piece of doubled-up fiberglass screen wrapped around the vent or drain line and secured with a tie-wrap works well as a bug screen in this situation, and fits anywhere.
2) It's not the bugs you can easily see that can kill you, it's the invisible ones that can be deadly.
3) Personally, I have never seen bugs in a water tank, only mildew.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
FleckDreher is offline   Reply With Quote
Old 09-07-2020, 05:50 PM   #23
When our MH was new I noticed the pex overflow lines went through the floor and where wide open so anything could crawl up in them and into the tank. So I installed rubber, duck bill checks on both of them. They seal up very well but still seem to let enough air in when the pump is on so the tank doesn't collapse with the suction.
markb422 is offline   Reply With Quote
Old 09-07-2020, 06:08 PM   #24
Originally Posted by Chuckinca View Post
All City Water Lines are full of mud and other nasty stuff but are chlorinated and usually safe to drink.
Not sure what city that kind of water is distributed in but where I live the water is filtered before it leaves it's mountain source. Public works also regularly flushes the mains to prevent any "mud and other nasty stuff" from accumulating. I get an annual water report that shows the level of "turbidity" and our water has little or none.
Now I have heard stories about cities along the Mississippi. They say that cities near the mouth of the Mississippi are distributing water that has been through several digestive tracts upstream
I think the OP's problem was un-screened overflow/vent lines. A 1/2" ID pipe is literally a "bug freeway".
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-07-2020, 06:25 PM   #25
You should look inside the pipes of your home plumbing.....
NavyLCDR is offline   Reply With Quote
Old 09-07-2020, 06:43 PM   #26
How do you access that area where the tank is on the DX3? Under the TV of course, but is there an easy way to do it without hacking anything up?
—john
johndjmix is offline   Reply With Quote
Old 09-07-2020, 06:44 PM   #27
Several years ago when I replaced the regulator I found nothing in the lines.
Years ago our water utility constructed a huge water filtration plant and from there water is all transported or stored in closed pipe and enclosed tanks. No open reservoirs like many cities.
In fact our water is clean enough a huge water bottling plant wanted to locate here.
2004 Nissan Titan
Old 09-08-2020, 09:53 AM   #28
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
No matter the water source, mould spores enter the water tank through the air vents. There is nothing that I know of to prevent this except keeping the inside of the tank bone dry, proper sanitizing with bleach is the best method I know of. The trouble is, once the mould bites into the plastic it is nearly impossible to get it out.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 09-08-2020, 10:07 AM   #29
Agreed. I prefer to do a "continuous sanitizing" with my tank. Rather than a once per year shock treatment of chlorine, I add chlorine (Clorox) at the rate of 1/2 tsp per 5-6 gallons. When tank is empty I add 3.5 tsp of Clorox and fill.
This is what Clorox recommends for emergency treatment of "clear" water. It then sits in the tank while traveling and when I draw the water from the tank it's filtered through the onboard filter and tastes exactly like the water from my refrigerator's filtered water dispenser.
Good luck to any mold that shows up in my tank although I have a gravity fill and the vent is pretty well protected.
2004 Nissan Titan
Old 09-08-2020, 11:24 AM   #30
I don't know if I should worry or not.
I've never put water in the tank of any RV that I've owned in 15 years of traveling. We drink and use bottled water when camping. We always stay at campgrounds with water hook-up and it is always filtered at the source, sometimes twice. We also use a filter pitcher. We never boondock so I don't see the need to fill, sterilize, empty the water tank and lines.
E T F is offline   Reply With Quote
Old 09-09-2020, 08:10 PM   #31
vasnipe's Avatar
Fresh water tank slime
My fresh water tank has a large screw in plug in the top that I remove to inspect the tank every now and then. Haven't found any surprises, yet.
Originally Posted by emm-dee View Post
If you think the first pictures are bad then don’t ever look inside the water tanks used on passenger aircraft. I’ve seen some where the gook on the bottom and sides could be scooped out with a spoon.
Nasty, slimy, gooey stuff.
I had the dubious pleasure of being a QA inspector on an aircraft carrier when one of the fresh water tanks was opened for cleaning and inspection.
Yeah, scoop up with a teaspoon?
Try having to use grain shovels and dust pans. When we first opened it up the slime was a good 2 inches deep.
I promptly suppressed that memory, until now...
And I will try to not think about the aircraft water tanks on my next flight.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 09-09-2020, 09:16 PM   #32
Usually Confused Member
emm-dee's Avatar
Before retiring I had to get on an airline flight 5-6 times a month, sometimes more. I NEVER drank anything or consumed any food unless I had personally brought it on board. One of the best pleasures of being retired is not having to get on an airplane or have to deal with anyone associated with commercial air travel.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 09-09-2020, 09:28 PM   #33
Iwannacamp's Avatar
Did you ever try to drain it?
I never put water in mine either, but every time I pull the handle it has a few gallons in it.
2017 Puma 297RLSS
Old 09-09-2020, 09:32 PM   #34
B and B's Avatar
I run a pre filter, then water softener. My pre filter is double carbon filters on less than ideal sources. Most provincial parks are on city supplied water that is well treated. My trailer has a built in high capacity filter that the tank or city water runs through depending on Anderson valve position. In spring I add some straight up city water and flush item system. Never had a problem with any trailer in 12 years doing this.
Old 09-10-2020, 04:52 PM   #35
AWF1945's Avatar
I've used this stainless pot scrubber/ brillo pad in the overfill/vent hose. No problem this far. The tank drain on mine is a pex tube just in front of left rear dual tires. It has a open/close ball valve, so if closed nothing is getting in.Click image for larger version
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 09-10-2020, 06:08 PM   #36
MoJoe1003's Avatar
Anyone have a source for the house water filter on a DX3 or XL. I’ve changed it before but I cannot find the record of my purchase. It’s time to replace it. I’ve seen on the forum, but when I tried to search for it nothicame up.
Joe & Cynthia
2018 Dynaquest XL 3801 TS Cindy 'B'
2018 Jeep Wrangler Unlimited Sahara
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 09-10-2020, 06:30 PM   #37
dbutton's Avatar
I have been using Calcium Hypochlorite, which is a pool cleaner, but if you read up on Clorox as a disinfectant, it has a shelf life, deminishing quickly even though it smells like Clorox.
The granulated Calcium Hypochlorite lasts much longer & is recommended for potable water sanitation & sanitizing.
Research is your friend. There are dangers but look it up & it works with less smell & taste.Click image for larger version
David & Mary Button - Ithaca NY
2011 Dynaquest XL 36' Freightliner
Cummins 330/1000
2009 Silverado 2500HD
2008 Corvette - 2011 BMW 335xi - Honda Valkyrie
dbutton is offline   Reply With Quote
Old 09-14-2020, 07:03 PM   #38
What a great thread. Thank you RANCHER ROB for sharing your story and leaving a solution. Another winter project for me.
A comment on water. I camp near West Yellowstone each year for 4-5 weeks while fly fishing. The water is still a light "pee" yellow after filtering it twice through carbon filters at a full hook up campsite. Thus I do not drink, cook, make ice, nor brush my teeth with it. I use Zero Water filtration, the filter is good for 27 gallons and I count how much I have used through a filter. West Yellowstone is 5 miles via a gravel road, and 6 miles of paved road and everything is more expensive (Bear, Bug spray, water bottles) so bottle water is not always one's best choice.
Tahoe John is offline   Reply With Quote
Old 09-14-2020, 07:04 PM   #39
Señor Miembro
Rancher Rob's Avatar
Mojo,
Here is the stock filter our rigs use on amazon.
But it is actually cheaper to order it through dynamax. Just much less convenient and slower.
Calcium HypoChlorite is great stuff! I think 2-4 little asprin tablets would sterilize the whole tank. Gotta be careful with it as it is an industrial oxidizer and it will destroy most anything in the general vicinity of where it is stored. Even seems to affect wood, plastics, and cardboard. Stainless steel and chrome don't have a chance.
Also, the stuff I have at least, looks like candy to little kids. I set the bag on the counter for a minute while I looked for my coat and hat to take it out to the well site. Next thing I know, my 5 year old little girl got into it. It was terrifying for an hour or so with all the emergency responders around and my little girl choking, coughing, and crying. Luckily she didn't fully ingest any of it and she is fine. I don't know how she even got past the noxious fumes of opening the bag. I was lucky that day.
Rancher Rob is offline   Reply With Quote
Old 09-14-2020, 07:26 PM   #40
Smittty
Water Tank
While we are all talking about the FWT. I have never been able to totally drain mine. I removed the access panel so I can see the tank and even after draining it is about 1/3 full. I have tried driving while valve is open, opening other valves to give air flow, tipping MH a and nothing seems to work. Even tried writing to Coachman and they suggested angling MH towards drain. That did not help.
Smittty is offline   Reply With Quote
fresh water, tank, water, water tank
