Resolved
I really don't know but, this is what happened. First I prayed, then I pushed the handle to the closed position (it had been stuck with the handle open.). Then, using the keypad I locked, unlocked a couple of times.
Then, crawling into the RV through the cab door (I am not tall enough for those steps). I locked, unlocked the door from the inside. Tried the handle from the inside and it opened. My son-in-law came over, took it apart and found nothing wrong.
Speculation: When I tried to open the door from the outside and it stuck in place, apparently the lever jumped off the spring plate inside the door and would not move. When SIL put it back together, he made sure the screws were tight. Possibility that screws were not holding plate tightly and allowed it to move slightly out of place.
But, happy now, the door works! Thanks everyone....
Jim & Gerry
Louisiana
Dynamax DX3 37 TS
Jeep Renegade
