DX3 air conditioner wiring question
I've got the coach connected to a 20A circuit in my garage to keep the batteries charged. With very little on other than the residential fridge/freezer, the control panel shows the coach pulling around 3 - 4A. It's getting hot down here, so, while working in there the last couple of nights, I decided to try to turn on the forward AC unit. It came on fine, cooled fine, and, while running, the control panel never showed more than 11 - 12A. All good.
What I found strange, though, is that when the compressor first kicks on, the inverter switches from 'AC In/Charge' to 'Inverter On' for about 30 seconds. I thought that the AC units were wired direct to shore power and/or the generator, and, as such, would have no bearing on the inverter whatsoever...they'd either have enough input current to turn on, or they wouldn't. However, it seems that the system is actually kicking over to house batteries to find enough current to spin up the compressor.
Can someone help me understand what exactly is happening in this case? For what it's worth, I do have the inverter input setting changed to reflect the 20A circuit it's connected to.
Thanks!
JT
2018 DX3 37BH
