Old 09-28-2020, 10:43 PM   #1
EdandShelley's Avatar
DX3 & XL Bedroom Side Override
Have been hunting for a past discussion but canít find the thread....
Is there a specific design / engineering need to have the ignition on to operate the bedroom slide? We donít need the ignition on the the living room. So curious as to why isnít designed this way? And... if itís not an issue, has anyone bypassed the need for the ignition being on?
Should have included the Force in the topic as well. Sorry about that.
EdandShelley is offline   Reply With Quote
Old 09-29-2020, 03:40 AM   #2
JC70's Avatar
Am I missing something? We do not have the engine running for the bedroom slide. Is that typical for the DX3's and XL's? Or was this a running design change for Dynamax.
Sheila and Joe
2020 Force 34HDKD - XLRB next March
2016 Jeep Grand Cherokee
JC70 is online now   Reply With Quote
Old 09-29-2020, 05:52 AM   #3
MoJoe1003's Avatar
Itís typical. We have to have the ignition on or engine running to operate the bedroom slide on our 2018 XL. The living room and galley slides do not require it.
Joe & Cynthia
2018 Dynaquest XL 3801 TS Cindy 'B'
2018 Jeep Wrangler Unlimited Sahara
ďBreathe in, Breathe out, Move onĒ
MoJoe1003 is offline   Reply With Quote
Old 09-29-2020, 06:52 AM   #4
JC70's Avatar
K. Thanks for the reply. I'm struggling with the design/engineering reason for that. I understand adequate voltage for the batteries for the slide motors but otherwise I can't follow the ignition on/engine on to open the slide. Curious. Not a big deal for me now and maybe not when we pick up our XL next march but curious nonetheless.
Sheila and Joe
Old 09-29-2020, 07:23 AM   #5
Motorized GM
It has to do with the parameters of the slide OEM.
The living room slide is a power gear system the bedroom slide is a Norco cable slide. They both have different "suggested" parameters...I have told our guys that I want it ONE WAY. In my mind, suggestions are just that.
There is a school of thought on ignition lock out vs. E-brake lock out. They both used to work just fine, but with some OEM's going to digital signals, it makes the E-brake one more difficult. Lithium would solve a lot of that pushing higher voltages.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 09-29-2020, 07:31 AM   #6
JC70's Avatar
Merci. We'll deal with it either way.
Sheila and Joe
Old 09-29-2020, 07:54 AM   #7
MoJoe1003's Avatar
Itís not a big deal, but it would be nice if it was the same as the others. Only time itís a hassle is if I put the to forward ones out first and then just trot on back to the bedroom and push the slide button only to realize I didnít turn the ignition on, duh, now head back forward, turn the ignition on, repeat trip back to the bedroom. If my memory was better it wouldnít be a hassle at all!
Joe & Cynthia
Old 09-29-2020, 08:13 AM   #8
Thanks Brian. Appreciate the explanation on why it was engineered this way.
Same as Joe...itís just an inconvenience. Decided to ask since I had just forgotten to turn the ignition on again.
Old 09-29-2020, 12:36 PM   #9
slide lockouts
Typical, Ignition OFF for jacks, then back ON for rear slide. Counterintuitive for sure. Fun Fact (that does not help at all) If you use the Plex app the ignition has to be ON for both slides. That is for a 2019 DX3.
BrianSB is offline   Reply With Quote
Old 09-30-2020, 03:02 PM   #10
TRN
Well, that's interesting as mine is the exact opposite for the rear slide. Ignition on, nothing. Ignition off, works just fine. 2015 DX3 37TS
2015 DX3 37TRS - Brutus
B'ham - or at a racetrack
TRN is offline   Reply With Quote
Old 10-01-2020, 07:01 AM   #11
Bill Davis's Avatar
What ever happened to hydraulic slides. They were quiet, smooth, and had a lot fewer issues. I understand the need for electric on the smaller RVs but not on the super Cs.
2008 Dynaquest 340xl
Bill and Carol
Retired mechanic
US Army Veteran 🇺🇸
Previous coach 2017 Isata 3RW
Bill Davis is online now   Reply With Quote
Old 10-01-2020, 11:59 AM   #12
Worm43's Avatar
You just get used to the engine being on. We pull up to site. Puts jacks down then put out all three slides then turn engine off. Leaving is just the opposite.
2017 Dynaquest 37XL RB "Thor"
2016 Jeep Wrangler JKU
Worm43 is offline   Reply With Quote
Old 10-01-2020, 02:23 PM   #13
Not sure if you may have typed that incorrectly....my bedroom slide in my DX3 wont work WITH the ign on. It must be OFF for it to operate!
--John
johndjmix is offline   Reply With Quote
Old 10-01-2020, 04:34 PM   #14
Worm43's Avatar
The 17 XL, the engine must be running for the jacks and all three slides. 2 electric and 1 Power Gear.
Old 10-01-2020, 05:09 PM   #15
This is sounding like there are different system configurations ..
On our 2018 XL
Ignition must be ON for bedroom slide to operate
Old 10-01-2020, 05:11 PM   #16
All 3 of mine work with the ignition off
NV DX3 is offline   Reply With Quote
Old 10-01-2020, 05:17 PM   #17
Worm43's Avatar
Not positive about the Power Gear but the jacks and Noco slides need the engine on to function. As a best practice, I would not run the Power Gear slide off the batteries by themselves. So why the engine is running, all three slides go out.
Old 10-01-2020, 05:17 PM   #18
Sunset beast's Avatar
My 2016 DX3 the ignition off for all 3 slide operations, in fact if the ignition is on the bedroom slide will not operate and if the bedroom slide is out the engine will not start.
David
David & Tracy
2016 DX37TS
Greensburg, Pa
Sunset beast is offline   Reply With Quote
Old 10-02-2020, 06:16 AM   #19
MoJoe1003's Avatar
On our 2018 XL
X2
Joe & Cynthia
Old 10-02-2020, 06:37 AM   #20
JC70's Avatar
Appreciate all of this data. At the very least, I will now be more aware and will set up a check list/procedure that makes the most sense for us. Good stuff.
Sheila and Joe
bed, bedroom, dx3, roo
