08-17-2020, 10:31 AM
DX3 bath accessories
I have a DX3 on order. When it arrives later this fall, I’d like to add a few more towel bars and towel rings in the bath and shower areas. I can find lots of different types online, but none exactly match the type Dynamax installs at the factory, i.e., those with exposed mounting screw heads. Does anybody have a source for the type installed at the factory? The dealer is being a bit unresponsive.
08-17-2020, 10:55 AM
Kanadian Kamper
Brian should be along to provide you with all your shopping needs real soon..........
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
08-17-2020, 01:08 PM
Commercial Member
Originally Posted by 5rvers
^^yes this^^
They're not all that exciting. She or Mark (east side of the country) should be able to get you exact versions.
55-BH-TBP1609-BSN END POST, TOILET PAPER AND TOWEL 5/8" BRUSHED SATIN NICKEL. Each rig takes (4) of these.
90M33097A ROLLER, TOILET PAPER PLASTIC WHITE (one of these)
30I02032A BAR, TOWEL 5/8 X 18" BRUSHED SATIN NICKEL (one of these).
Of course you can order as many as you want.
Myself, I love hooks. Hang the towel, no folding needed
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (Do Not Ask in a PM) so others can benefit from the answers.
Sales-Service-Parts https://dynamaxcorp.com/contact-us
08-17-2020, 05:07 PM
Thanks. That helps. I’m reaching out to Sarah. I, too, prefer hooks and plan on more than a few. The wife wants the towel bars and ring.
08-18-2020, 10:40 PM
We thought about more rods but went with this and hooks on the back of the door. Great storage while traveling and easy access in back of bathroom door. Also hooks are great place for them to dry.
08-19-2020, 09:17 PM
Señor Miembro
Do you have a link for those towel hooks, please?
08-19-2020, 09:41 PM
Sure Rob... Here you go...
Ed
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
08-19-2020, 11:05 PM
Señor Miembro
ordered it. Thanks buddy!
08-19-2020, 11:23 PM
Wall is too thin for screws to secure the rack. I used exploding rivets.
Worked great. Amazon description...
Racer's Speed Shop Mill 3/16" Small Head Tri-Fold Exploding Aluminum Mandrel Pop Rivets 50 Pack
08-30-2020, 01:51 PM
IMPORTANT UPDATE
DO NOT DO THIS UPGRADE WITH STAINMASTER FLOOR PLANKS. Lowes said they would work great for a wall. They did... until we put the RV in storage and the temp went into the 90s.
Will update on what I do about this. Weighing options for reattaching since wife loves them and it looked very good.
Would appreciate any thoughts for permanently attaching these.
08-30-2020, 04:31 PM
you could always use a construction adhesive, just knowing that it will be pretty much permanent. If you want to remove it, it will take off the wall covering with it.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
08-30-2020, 05:55 PM
yep... my wife is reminding me that I should have done that in the first place...she recommended it....
08-30-2020, 06:58 PM
What is your current attachment method? I have high end vinyl plank flooring in my condo and it just floats with a foam backing, no adhesive whatsoever. I do know the vinyl expands in the heat and will pop up if no expansion gap.
2021 Isata 5 30FW
2022 Ford Ranger Tremor 4x4
(Previously owned a 2017 Isata 3 24FW)
08-30-2020, 07:16 PM
The planks have adhesive...peal off the protective cover and stick them up. They are designed for flooring and we were told they would work for the wall. Guess they would have if the internal temperature remained below 80 degrees.
08-31-2020, 07:45 AM
Commercial Member
Welcome to our world....
Where we have to find products that work at 40 below zero and 120 degrees above zero, in 10% humidity and 95% humidity.
08-31-2020, 08:26 AM
Originally Posted by bclemens
...find products that work at 40 below zero and 120 degrees above zero, in 10% humidity and 95% humidity.
Have you tried concrete?
Mike&Donna
2013 Dynaquest 390XL
On the dolly:
2012 Scion iQ (Inclement weather & grocery getter)
08-31-2020, 08:34 AM
Commercial Member
That and steel seem to handle it pretty well. Looking for a nice 24"x36" steel floor tile.
08-31-2020, 09:24 AM
Ok. That’s the solution!
I’m telling the wife I’m putting diamond plate up!
08-31-2020, 09:35 AM
Commercial Member
Actually there is a company that "prints" on aluminum sheets. That is a close second.
Also, LCI has a division that prints on glass. "easy to clean"
