Originally Posted by bclemens
Our cooktop I think just pulls out. Literally. It then has a cord to an outlet inside.
"U" from what I knew was that it did not recognize the proper pan, you were not on the proper burner or you were not positioned properly.
Brian,
Is there a reset or something? The pots and pans are the same ones that came with the RV and whatever pan it shows that code on, I can move the same pot to the other burner and it works.
I've tried at least 4 pots or pans on both burners and they all work on the other burner.
Any thoughts?
Thanks,
Mark
