Old 05-18-2021, 04:09 PM   #1
DX3 floor construction
I have found very little that talks about how the floor is constructed. What materials are used and where? Thanks.
steadfast is offline   Reply With Quote
Old 05-19-2021, 07:55 AM   #2
Motorized GM
You don't list a year, so I will assume new. This video walks through the entire process.
and includes pictures at various stages.
Basically a steel chassis upfit, aluminum framed floor filled with block foam insulation. The underside of that floor has a composite material (no wood) to keep out moisture, the top of the aluminum frame is tonge and groove plywood, though at times we have run jumbo sheets of OSB...both have their pros and cons.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 05-19-2021, 08:38 AM   #3
Thanks. So if I understand, the composite material becomes the top of the rear wheel well?
Old 05-19-2021, 08:50 AM   #4
Motorized GM
Not exactly. While the composite does cover the entire underbelly, we then put galvanized metal at the top of the wheel well. That goes over top of the composite material (or under if we are speaking bottom to top).
Name:	Wheel well 2.jpg
ID:	254892   Click image for larger version
Name:	Wheel well 1.jpg
Old 05-19-2021, 09:01 AM   #5
Got it, thanks.
Old 05-19-2021, 09:51 AM   #6
cmulvey's Avatar
Thank you for sharing. Very informative.
Christian M
2021 Forest River Forester 3011DS
cmulvey is offline   Reply With Quote
Old 05-19-2021, 11:31 AM   #7
While on the topic, how do we remove the composite panels in between the frame rails if we need to get to something under them?
--John
johndjmix is offline   Reply With Quote
Old 05-19-2021, 11:35 AM   #8
Motorized GM
--John
Well that depends on what year you are referring to. We have altered our construction. But in a nutshell, you don't. You would have to cut it out. It is like removing the plywood decking....you typically don't. You would cut a piece and patch.
Old 05-19-2021, 04:08 PM   #9
Even with that in mind that you may have to cut to access an area, its a great feature. Many coaches dont have that composite in between the rails!
--John
Old 05-19-2021, 06:28 PM   #10
MoJoe1003's Avatar
I assume you can screw into that composite material, yes?
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
MoJoe1003 is online now   Reply With Quote
Old 05-19-2021, 08:12 PM   #11
Motorized GM
negative.
Most OEM's use a woven polypropylene by itself, over lauan, or thin fiberglass none of which has any screw retention. We decided just under a year ago to move to a more automotive product, but it is still only about 3/16" thick. It is a composite along the lines of a sturdier azdel with a water resistance film laminated to it. So it takes wood out of the equation.
If you are looking to attached to something, then you would need to screw into the top perimeter of the cargo boxes. They are fastened into steel angle...just stay inline with the existing cargo box fasteners and you should be fine (just confirm there are no harnesses tucked in behind)
Old 05-20-2021, 12:07 AM   #12
MoJoe1003's Avatar
Glad I asked! Thanks for the info.
Joe & Cynthia
Old 05-24-2021, 01:48 PM   #13
CyberShanks's Avatar
Location: Top of a hill (in Iowa) surrounded by corn. Dynaquest XL 3400KD getting built for us right now!
So, curious about the tile floor in an XL? The video shows sill plate of the walls getting screwed into the floor. How do the walls get attached when there are polished tiles in the way?
Jim
CyberShanks is offline   Reply With Quote
Old 05-24-2021, 02:02 PM   #14
Motorized GM
Jim
They aren't. We put plywood strims down on the floor where the walls go and tile up to that area (or close to that area). Walls are screwed (and rest) on the wood block/shim.
Old 06-07-2021, 08:51 PM   #15
negative.
This forum is a wealth of knowledge and the company’s willingness to engage directly is greatly appreciated - since you mention the cargo boxes here, is there any steel angle on the bottom edges of them if someone was looking to mount slides for trays or a fridge?
SRLETX is offline   Reply With Quote
Old 06-08-2021, 09:24 AM   #16
Motorized GM
There are steel angles at the top, so you could create a cradle as others have done already. Lots of options. On some of the new ones we have a steel support angle, but I would still tie in at the top where you have the most strength....and it is the same install no matter what model year.
Old 09-20-2021, 04:20 PM   #17
Interior walls/tile
I am shopping around for an estimate on replacing my tile floor in our 2018 DX3 ts. If the cost is astronomical I may do it myself but have a few questions.
Can someone tell me if the bathroom wall and the shower stall are installed over the tile? Those two areas look like the major troublesome points. Am I going to have to remove them?
Love the coach but the tile lifting and cracks are a pain, literally when stepped on without shoes or slippers! Im a Nam vet with diabetes from agent orange and damaged to my feet is a major concern.
Any help with would be appreciated, or a name of a service center where someone has had this done would really be appreciated!
Thanks, Fred.
Fred & Ellen
2018 DX3 37TS
Disabled Nam Vet
2020 Diesel Rubicon Unlimited with stuff 🤪
Fredski007 is offline   Reply With Quote
Old 09-20-2021, 04:25 PM   #18
MoJoe1003's Avatar
This picture may answer your question. Tile floor goes in before anything else and runs edge to edge.
Joe & Cynthia
Old 09-20-2021, 04:43 PM   #19
Tile
Attachment 263119
Thanks Joe, I could be wrong but that doesn’t look like ceramic tile to me, is it?.
Fred & Ellen
2018 DX3 37TS
Disabled Nam Vet
Old 09-20-2021, 04:47 PM   #20
MoJoe1003's Avatar
No we chose the LVT. Had the tile in the first one. It got replaced with LVT and we really liked it. Warmer on your feet and no more cracked tile or grout. So, ordered the 2021 with LVT.
Joe & Cynthia
dx3, floor
