10-14-2017, 11:31 AM
Eat Pray Love
DX3 Main Slide will Not come in - Upstate NY
Well we were 95% packed to travel from Upstate NY to Ca. The night before leaving I tried putting slides in. The rear one came in but the large main one didn't. The control module for In and Out was normal (Red light flashing slowly)
Without any documentation I tried/checked many things. This DX3 main slide has a Power Gear slide-out mechanism made by Lippert Corp w/emergency retract module. We found 3 manuals on the internet. The slide is run In and Out by 2-DC motors.
We are tied to 50 amp shore power. Coach batteries were at 13.2 volts or higher. Checked DC fuses in fuse box and on retract mod. Checked as best I could wiring, I didn't notice any fault codes but held OUT and In buttons on touch-pad to clear,if any ,minor faults, Held Set Stop/Clear Fault button on back of wall touch-pad for over 5 sec. to clear any major faults. Nothing helped.
I then tried Manual Crank mode. Disconnected sensor connectors. Disconnected motor brakes and used 3/4 hex coupler to move slide.I was able to move Forward gearing but Unable to move aft gearing. This is where I left off until I talk to some experienced helper. On Dynamax Owners I was told to contact Steward Systems in Elkhart,IN.@ 574-262-0225. Monday I'll call, unless I or you can think of other testing. Our trip is therefore - on hold til we find a fix.
tom edelman 2016 Dynaquest DX3 37RB
(This was to be our maiden voyage - :O( ).
Keuka Park, NY
585-733-6018
10-14-2017, 02:22 PM
Sent some pictures to your phone and called you.
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
10-14-2017, 06:16 PM
Retired Army Paratrooper
Make sure the ignition is in the off position, mine does not work with key turned on.
Dennis & Zoleta
Retired US Army
2010 Grand Sport GT
10-15-2017, 07:42 AM
I had an issue with the main slide. I went out an inch and stopped then wouldn't go either way. But I got a major fault indicator.
That being said, I was able to crank it out and back in using two 1/2" drive ratchet wrenches. I'm going to assume you've released the motors and you're using a partner to crank both sides at the same time.
Also, if you have a smartphone or tablet, download the Dynamax app. You can get all the manuals from that app if for some reason the one you need isn't in the manuals included upon delivery.
My issue turned out to be a bad motor. We stopped in Elkhart on the way home and it was replaced in a matter of hours.
MasterBlaster is correct. Make sure you're ignition is off. I disconnect the water and sewer, bring in the slides, awning, then levelers. Next I disconnect shore power. Only after this is all done do I start-up, warm-up, unchock the tires, and move out.
Is your rig leveled? If not try leveling it. I always level before extending the slides and retract the levelers after bringing the slides in.
If you need someone to talk you through anything just give me a call: 717-329-2030.
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
10-16-2017, 09:00 AM
Eat Pray Love
Our DX3 Slide
Removed main slide motor aft. Checked brake for rust corrosion - OK, Checked movement of shaft with 3/4' socket - moved OK. Reinstalled gear motor aft. Flat Gear bar was lower than front flat gear bar. Jacked and positioned gear bar higher aft - No movement still after these procedures. Binding in rear slide assembly -I'm clueless - why? Monday 10/16/2017 10:00AM calling Dynaquest in Elkhart, IN. for any help.
Called Stward System first: Chuck theredoesn't work on Power Gear products. :O(
Called Dynamax, IN Customer Service "Brian" No Help refered to LCI Libbert Components Incorp. 574-535-1125 Ext 2 call center. Sending info via e-mail.
10-16-2017, 09:21 AM
just read your post. Give me a call
Joe & Debbie
10-16-2017, 01:25 PM
Commercial Member
Still no error codes? If you cleared the faults, you likely cleared the stop settings as well. You would need to reset the stops.
Look at page (3) on this sheet. (just in case that is the issue). we have seen slide tops lost due to low voltage.
10-16-2017, 04:04 PM
Eat Pray Love
Slide Main
As soon as we get this slide to come in we will be heading to the factory and have everything checked out. We were scheduled to be there today for the other slide topper re positioning until this problem occurred.
Tomorrow 10/17/2017 we have a crew of men coming over. I will take out the aft main slide motor and disengage the forward motor. We will push on the slide (hopefully) Inward. This is what LCI told me to do. Tomorrow will be the big test. After that God only knows what I should do if this doesn't work. Keep your fingers and toes crossed, wish us luck and say a little prayer. Tom E
10-16-2017, 04:14 PM
Let me know how you make out Tom, especially, when you find out what the problem was ?
Joe & Debbie
10-17-2017, 07:25 AM
Eat Pray Love
OK Joe
10-17-2017, 11:43 AM
Commercial Member
well, I thought I saw your name on our service calendar, but now it is not there...so not sure what happened.
10-17-2017, 12:57 PM
Eat Pray Love
It'll get there to Elkhart and get another appointment... when... ?
Besides service Janis and I look forward to a great visit and tour.
10-17-2017, 02:47 PM
Eat Pray Love
Hurray!!!
10/17/2017 15:30
Three husky young men showed up. We took turns cranking on forward slide motor w/ 3/4" socket (clock-wise). Two men forward and one guy aft pushed on slide keeping the same distance side to side from main frame. Took us ~ 30 mins. to get the entire slide to "IN" position. I locked the brake on the forward slide motor. (remember aft slide motor was removed).Positioned bars on interior top of main slide to assure no movement while driving.
Yeah !!!!!
Tomorrow we'll start out for Elkhart, IN to fix slide.
10-17-2017, 03:02 PM
Glad you got the slide in. Did the aft slide bar go in smoothly while pushing?
If you put on the gear box assembly, you probably wont have to worry
about slide moving out. I drove 400 miles like that.
Still interested in what they find wrong with the slide? Make sure you let
me know. In meantime, have a safe trip to Elkhart..
Joe & Debbie
10-17-2017, 09:26 PM
Eat Pray Love
Not to smooth. It took a lot of grunting and sweat. BUT it IS IN
10-22-2017, 04:15 PM
Eat Pray Love
Slide Fixed
Made it to Dynaquest. Lippert tech. was summons and found a wire to the aft motor bad in harness. That wire took out sensor in Slide motor making the slide inoperable. The control In/Out switch was also bad. Dynaquest Tech. installed another aft slide motor and control. Walla, all is good again.
Thanks to all involved in this matter.
