Old 08-05-2020, 04:23 PM   #1
Dx3 Oil Change - VERY Easy!
Just finished the first oil change on my 2018 DX3. It was one of the easiest oil changes ive ever done on anything.
First off i was thinking...i dont have a pan big enough for 6 gallons of oil. The trick is, you dont need one =). When you go to drain the oil, drain the rear (high) plug on the pan first, about 2.5 gallons comes out. Then do the front plug where the other 3.5 gallons will drain. Easy and no mess.
The oil filter looks like it will be tough to remove...not so. Use oil filter plyers and it will come loose. Carefully lower it down and it wont even spill.
Fill and throw on the new filter and fill with oil.
Easier than changing the oil on my Ford Raptor.
--John
johndjmix is offline   Reply With Quote
Old 08-05-2020, 07:07 PM   #2
halla's Avatar
You changed the fuel filter and fuel/water separator too right? Should change them all at the same time, at least I do.
2018 Dynamax Force HD BH---Just Rite-2
halla is offline   Reply With Quote
Old 08-05-2020, 07:48 PM   #3
AWF1945's Avatar
And air dryer filter. Just make sure you bleed all the air first.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 08-05-2020, 08:22 PM   #4
Agree! The hardest part is lifting a 'mostly filled with fresh oil' new filter up from beneath the rig and getting it started on the housing threads (assuming you put fresh oil in your filters before installing new ones). A hundred times easier than R&R'ing the filter on my ram cummins.
Also, X2 on what the other guys above have said. Do it all and be done with it.
2018 DX3 37BH
mookieblaylock is online now   Reply With Quote
Old 08-05-2020, 08:25 PM   #5
I did get both the separator and the fuel filter but I only have 7,000 miles on the coach, it would be a waste to install them now. Instead I put them in a compartment. Will do next oil change.
I was wondering...is there a def filter? What if some grit got in the DEF tank?
—john
Old 08-06-2020, 02:15 PM   #6
AWF1945's Avatar
Yes there is a DEF filter.. not sure what the interval is.. good question. I'll research that one
Old 08-06-2020, 03:13 PM   #7
MoJoe1003's Avatar
It’s 200,000 miles or 6500 hours
Joe & Cynthia
2018 Dynaquest XL 3801 TS Cindy 'B'
2018 Jeep Wrangler Unlimited Sahara
“Breathe in, Breathe out, Move on”
MoJoe1003 is offline   Reply With Quote
Old 08-06-2020, 04:32 PM   #8
AWF1945's Avatar
Lol... well I have aways to go.. thanks
Old 08-13-2020, 11:05 AM   #9
MoJoe1003's Avatar
Are these the two drain plugs we’re talking about? One upper, one lower?
Joe & Cynthia
Old 08-13-2020, 11:12 AM   #10
MoJoe1003's Avatar
Or is this the high one in the rear?Click image for larger version
Joe & Cynthia
Old 08-13-2020, 11:23 AM   #11
My Force with the 8.9 has two oil drains one forward and one at the rear of the pan.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 08-13-2020, 11:30 AM   #12
MoJoe1003's Avatar
I’m thinking the L9 in the XL may not. One of the several differences from the DX3 engine that I am beginning to discover. The plug in the second picture appears to be on the bell housing, so I don’t believe I should mess with that one. Just trying to confirm before I jump in screw it up somehow.
Joe & Cynthia
Old 08-13-2020, 11:33 AM   #13
MoJoe1003's Avatar
This picture is of the entire oil pan.
Joe & Cynthia
Old 08-13-2020, 11:35 AM   #14
Here is the pics
Name:	Fumoto Front.jpg
ID:	236492   Click image for larger version
Old 08-13-2020, 12:58 PM   #15
Interesting. Looks like you only have one. Better get a big drain pan! Or just use that valve and turn off between containers.
—john
Old 08-13-2020, 01:26 PM   #16
halla's Avatar
I had installed a Fumoto drain too, makes life much easier with oil changes.
Old 08-13-2020, 02:49 PM   #17
MoJoe1003's Avatar
I have a 23 qt drain pan. Just short of 6 gallons as fate would have it. So, that last quart ought to be fun!
Joe & Cynthia
Old 08-15-2020, 04:04 PM   #18
MoJoe1003's Avatar
Anyone with an XL done your own oil change?
Joe & Cynthia
Old 08-16-2020, 04:11 PM   #19
TRN
Changed the oil in my DX3 yesterday, second time since owning it (yearly change since I don't put more the 20K miles/yr on the unit). Tried your trick, drained the upper first, dumped the oil, then drained lower, moved the container, and then put a hole in the filter to let it drain completely. Install oil filled filter, add oil and then grab a beer. Whole process took about an hour and dealing with half the oil in the waste pan makes it so much easier.
2015 DX3 37TRS - Brutus
B'ham - or at a racetrack
TRN is offline   Reply With Quote
Old 08-17-2020, 08:24 PM   #20
Actually I didn’t even poke a hole in the filer. Just loosen it and carefully lower. Zero spilled out.
—john
dx3
