I took one apart awhile back and if i remember correctly the panel behind it is a solid electronic panel. The buttons you see just sit over the actuators underneath. I also believe that electronic panel plugs in with a phone/Ethernet type cable. So, I don’t believe you can rearrange the order of the buttons.
I get why you would want to. On our XL the first button on the panel in the bathroom is the water pump, the second button is the light. Seems it ought to be the other way around. People are constantly turning on the water pump when they go in there.
I just thought of it, since that is just a two button panel maybe I could remove the cover and flip the panel upside down, change the buttons in the cover and put it back on. I don’t remember how the actual buttons are attached to the cover, but I am going to check today.
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
