I can confirm that it is only available on the 28SS currently.
Now, in theory, if you used something removable to build up the lower section of the bed base when the slide was out (to make it level)...you could "deflate" the Innomax completely and remove that piece when you need to bring the slide in. It will compress. That just depends on how often you are using it and how often you are moving. A topper of some sort is normally an easier solution.
We have toyed with ways to make the Innomax work from the factory...but that's just R&D right now.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Correct. It shows just the 28ss on the order sheet however I rec'd a build sheet for an up coming 30FW available mid Dec and it had the Innomax bed option. I thought it was maybe a mistake...?
That seems to be what I have seen. I can get 10mpg running 65. But prefer to run 74...9.4-9.5 then.
