05-18-2017, 04:29 PM
Dynamax Force HD Toilet
I want to replace the Thetford Aqua Magic 2 in my 2016 Dynamax Force FKS HD. This toilet is horrible. I have replaced the ball valve seal twice on it and it will not hold water in the bowl. Any suggestions? I tried to install a Dometic 320 but it won't fit. It is to elongated and hits wall before I can get it flat on base. Thanks in advance for help on this. My wife is very unhappy about the sewer gases. It don't blame her.
05-19-2017, 08:17 PM
Just replaced our seal too, so far its holding. No idea what other toilet would fit. Going to use the thetford seal conditioner to see if that helps prolong the seal.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-19-2017, 08:31 PM
I ordered a new Thetford Aqua Magic 2. Apparently there is no other option with the clearance issue at the back I have been told. Halla maybe we both got a bad batch of them. I found the new one at Lazydays for $160 shipped. I ordered a set of snap pads today also. Lol
05-20-2017, 08:19 AM
Let me know if the new toilet works better.
Never heard of snap pads, just looked them up. That is cool. I use bigfoot pads, but have to get under the coach everytime. That would be nice to have them connected. Let me know how those work too. I think I would spray the jacks with a rust inhibitor, they are going to get a fair amount of moisture and dirt in there. Thanks for sharing.
05-20-2017, 08:28 AM
I had the pads on my fifth wheel and loved them. I sprayed the jacks with that rubberized coating in a can before I installed them. You won't be disappointed in the quality. Mine should be here early next week. As far as toilet goes... we shall see.
05-20-2017, 08:30 AM
I need to figure out what size snap pads now, Looked at my Dynamax product index sheet and the jacks are not listed. I think they are PowerGear, probably should measure the feet too.
05-20-2017, 08:34 AM
You want the Prime pads same as me. They are specific to Power Gear which we both have. I got them for $189 shipped with coupon code cart17
05-20-2017, 08:54 AM
Awesome, thanks. Just ordered
05-20-2017, 09:00 AM
Isn't this a warranty item?
05-20-2017, 09:07 AM
It may be. Not worth the hassle of dealing with a dealership to me.
05-20-2017, 09:37 AM
Have you looked at the Dometic 310? The rough in dimensions are a little different. It's not elongated but does have a turbo flush and is the same material as the 320.
05-20-2017, 09:43 AM
I saw the 310 but was unsure if it would fit. I can't afford to gamble anymore. I already have a brand new 320 in the box that the company won't return.
05-21-2017, 06:40 AM
Toilet seals wear out, but most commonly they are dirty and or dry. I clean mine thoroughly with CLR and then spray with silicone. That makes it seal. If you are using TST treatment from Walmart or the Geo Method, and your venting is good, you shouldn't have any smell from your toilet. The exception would be if you bathroom vent is sucking the air up from the toilet. Our houseboat had an unworkable vent from the factory. The black tank swelled enough to bend the angle iron holding it in place. Once we fixed the vent, there is never any smell. You might want to list your toilet for sale here. Someone will be able to use it.
05-22-2017, 12:21 PM
Having the same issue. Took the rig to the dealer and they "couldn't find anything wrong". The toilet held water for them for three weeks. I get it home, and its up to its same old shenanigans.
I'm also having issues with the black tank flush. It blocked up about two months after purchase (full timing) and never worked again. Took to dealer and they charged me $200 to clear it (not under warranty cause "nothing's broken". First time back on the road with it and its not working again. Now i'm 3,000 miles away and they won't do anything about it. So furious with them right now.
Gabe
2016 Dynamax Force 37BH HD
2016 Jeep Wrangler Unlimited - Rubicon Hard Rock
