Yes very easy.
I copied this from the forest river site last year.
If you have the overhead bunk option it’s located behind the 4 inch wide black trim piece that makes the U-shaped. It’s on the driver side, you do not have to remove the mattress, it’s the plastic trim under the mattress. Behind the first piece of plastic trim, before the U-shaped piece. There is a quick connect, pull out the wire to the down camera and replace with the wire to the rear view.
