Originally Posted by seels
As soon as I pull the trigger to buy the Isata 5 I am calling Kelderman. To me getting the rear air is a must since I am going to do some boondocking and I do not want to get stuck. I want to call them because I want to know if it is worth it to get the front airs installed by Dynamax and then have them do the backs and the leveling kit done by them. Or should I have Kelderman do the whole thing.
I think the front system from the factory has manual set levers with compressor and tank. Assume this can be used for the rear system. If you want to adjust height for short duration then you will need the electronic controls with adjustable bag levelers. So it may replace a few components from the factory install.
Give Kelderman a call to discuss want you want. Rear install takes 3 days.
