Old 04-10-2021, 05:45 PM   #61
twp5253's Avatar
Originally Posted by Isata5AK View Post
Mr. Clemens,
Do you have any recommendations for a particular brand(s) of lithium batteries and for the isolation unit? We have a 2019 Isata 5 36DS, and are looking at replacing our 4 existing lead acid batteries with two 100AH Lithium batts. Fall in Alaska can be cold so would be nice to have a low temp option.
Thanks!
https://ceb8596f236225acd007-8e95328...00-LT_1020.pdf
They are testing and pretty sure using the Relion batteries.
twp5253 is offline   Reply With Quote
Old 04-10-2021, 09:46 PM   #62
Relion. That is the choice of Dynamax and recent negative comments about Battle Born have raised some questions. The relationship between Relion and Dynamax will be useful if there ate any problems.
Battchief
Battchief is offline   Reply With Quote
Old 04-13-2021, 10:32 AM   #63
Commercial Member
Battchief
Any lithium battery supplier must be "corporate approved" before we can use them and that requires from testing.
As Battchief mentioned, we have had really good success with Relion. They were ahead of the game in regards to Low Temp (LT) version.
Lithionics is another supplier that has been used for a while at the Galleria division and their GM speaks highly of them.
Battle Born (rather their Dragonfly version) is also approved for us. We have tested a few sets, and would use them as well.
My #1 recommendation would be ReLion at this point since we have been running them for over a year now.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-14-2021, 12:54 PM   #64
BIM install
Had the LI BIM installed. Doesn’t look like they used 2\0 wire more like 4. Any concerns here? It does work. Turn on the chassis and in a minute or so you hear it engage and get a steady 50 amp charge. Had the converter changed to the lithium style and get the same now when starting the generator.
mlbrowninoh is offline   Reply With Quote
battery
