Originally Posted by mookieblaylock
Gotcha...I found a youtube video where a gentleman was grounding out a pin with a short piece of wire, but it wasn't clear which pin he was connected to.
Assuming this is more than the 'ABS light just won't go off', and there is indeed a problem, would the main ECU produce a code, or is the 'blink code' the only way to diagnose the issue?
when the ignition is first turned to the on position watch the light and see if it blinks. The main reason I didnt go through the hassle of installing a blink switch is that mine would blink the error code every time the switch was turned on. Do not start the motor...the blinking will stop with the engine running. It should flash a series of two digit codes. My coach is much older than yours so there might not be the same abs module or even the same code for that matter.
