Found the cause of our bays not unlocking.
Was checking the power connectors on the rear electric bay wall... all secure. Then the locks started working. Indicates a loose connector somewhere.
Next, traced the wire harness from the locking system to the RV wire harness and found a very loose connection in the unlock power wire. Pulled out of the connector very easily.
Will remove the pin, reattach the wire and reinstall the pin.
Wouldn’t have found this without the advice to look at the power connectors in the electric bay. Thank you!
