As the first reply said, it is very unlikely. Generally speaking the lights in your compartments are run on a 12 volt system. Assuming you mean a "home" outlet- cannot be installed as it is 120 volts.
There are a few options you could pursue to install an outlet in the location- but not by replacing the light receptacle.
2018 Cherokee 274DBH
2015 Chevy 2500 4x4 Crew Cab
Recurve R6 WDH w/Sway Control
Days Traveled:2021-51 / 2020-43 / 2019-37 / 2018-30
