Old 10-17-2020, 06:24 PM   #1
ENG BRK question - 2017 DX3
We're not noticing a difference between the ENG BRK switch when it's up vs down. We're assuming up= HI and down =LO. It does seem to be working, we're just not noticing a difference between the switch positions. Any insight?
GunTotnHippie is offline   Reply With Quote
Old 10-17-2020, 06:52 PM   #2
On ours, up is high and down is low like you mention. The only time Iíve noticed a considerable difference is when towing heavy and trying to maintain speed coasting down pretty decent grades. Thatís the only time Iíve ever gotten any additional benefit from switching it to high. Itís extremely effective on the low setting.
2018 DX3 37BH
mookieblaylock is offline   Reply With Quote
Old 10-17-2020, 07:02 PM   #3
Thank you!
Old 10-18-2020, 06:14 AM   #4
FOURWHL's Avatar
Yep. My understanding is on low it only uses 3 of the cylinders, so about half as powerful. Its a very slight difference on flat ground but get on a long steep grade and it's definitely noticable.
2016 Dynamax DX3 - Big Blue
https://fourwhl.com - Traveling the country in our DX3 for the next year
FOURWHL is offline   Reply With Quote
Old 10-19-2020, 09:00 AM   #5
Travler's Avatar
It might just be me but it seems that in high that it downshifts a little quicker to keep the RPM up to hold back more.
2017 Dynaquest 37RB
Travler is offline   Reply With Quote
Old 10-19-2020, 11:17 PM   #6
EdandShelley's Avatar
Works best in lower gears and higher RPMs. We came down 11,500 ft Wolf Creek Pass, CO without having to use the brake pedal on our 2018 Dynaquest XL. Engine brake on high, set trans to 4th gear and cruised down at about 40 mph.
EdandShelley is offline   Reply With Quote
Old 10-20-2020, 09:31 AM   #7
I have heard not to use the engine brake on wet roads. I'm guessing it could cause the back tires to slip.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 10-20-2020, 02:31 PM   #8
Agree. CDL course notes this.
dx3
