10-09-2022, 03:51 PM
Equalizer Jacks Won't Go Down
I attempted to level my coach today multiple times to no avail. When I turn on the Equalizer power, all my lights light up, which is correct, according to the Equalizer video I watched. They all turn off except the four individual jack lights. That has usually indicated I need to do an "All Retract" first, then after it quits beeping and the lights go out, hit "Auto Level" and the jacks go down.
In this instance, the "All Retract" never stops beeping and the lights stay on. If I cycle the power button off then back on and push "Auto Level" all I get is a beep. Pushing the individual jack buttons I can hear them connecting to the jacks, like a little bump sound, but the jacks do not move.
After watching the Equalizer troubleshooting video on YouTube, the guy basically described my problem and said if this is happening then unplug both of the leads from the back of the Equalizer switch, wait 15 seconds, plug them back in and the system should reset. Not so much in my case. Still have the same issue, jacks will not go down. There is power to all leads at the motor and the switch.
Got any ideas?
Joe & Cynthia
2021 Dynaquest XL 3801 TS Cindy 'B'
2021 Jeep Wrangler Unlimited Rubicon Diesel
“Breathe in, Breathe out, Move on”
10-09-2022, 04:08 PM
Make sure your fluid level is full.
10-09-2022, 04:59 PM
When in doubt, perhaps a full coach power reboot. Shore power disconnect. Generator off. Inverter off. Main battery switch in battery compartment off. That should be everything. Then reverse order to re power. If that doesn't work, I'd refer to the leveler manufacturer or FR experts. Did you try manually leveling?
10-09-2022, 05:19 PM
Fluid is full…checked that. Yes, tried to manually level, just hear a electrical bump sound when each one is pressed, so I know they are getting power.
I will call Equalizer tomorrow. They don’t work on Sundays. Unfortunately, I will be away from the coach for the next 3 days, so if they ask me to try some diagnostics the call will be for naught. I tried to do as much of the suggested troubleshooting as I could, so I could answer their questions.
Joe & Cynthia
10-09-2022, 05:33 PM
Sounds like you will be in good hands.
2021 Force 37TS (Detroit DD8)
2021 Jeep Grand Cherokee Trailhawk
2020 Isata-5 36DS (traded in)
10-09-2022, 05:39 PM
I will try the complete coach reboot. I think it’s a long shot since I already unplugged the control panel per the Equalizer video and it didn’t change a thing. But, heck, it’s worth a try, right?
Joe & Cynthia
10-09-2022, 06:28 PM
Sounds pretty much like what recently happened to me, in my case it was a bad motor but the jacks were down, of course. 😩
That thump sound is most likely the solenoid that’s strapped to the motor. You can test for a motor problem by looking for voltage on the motor, it’s a reversing motor depending on if your going up or down so polarity reverses controlled by the solenoid. With your Voltmeter check for voltage on the motor when attempting any operation of the jacks. If you hear a thump and see voltage on the motor than motor is bad, if thump and no voltage perhaps your solenoid or connections are bad, my ground (negative, black) was somewhat loose as well.
On my unit it was equalizer motor part # 3332, $206 on equalizers website.
It is a bit of a delicate operation to change that motor as you remove its bottom plate before replacing and aligning the drive shaft. Easy to drop the stator right out of the motor case, (ask me how I found that out 😑 .
If replacing motor the breaker is in the electrical bay back wall 80amp resettable breaker so it’s easy to turn off, push yellow button. Good luck! 👍
Jeff
2024 Europa 32KD
10-09-2022, 06:35 PM
Sure hope it’s not that! I’m leaving for a 9 day trip on the 21st.
Joe & Cynthia
10-10-2022, 07:27 AM
Best of luck with diagnosis Joe, keep us posted.
Here's hoping for an easy fix.
Jim
2021 Dynamax Dynaquest XL 3400KD
2022 Aluma 8220H Tilt flatbed to carry:
2012 Jeep JKU Rubicon or slightly modded 2001 Jeep TJ
10-10-2022, 01:40 PM
Spoke with an Equalizer tech this morning. He feels confident it is the contact switch or the pressure switch, maybe both. Since I am out of warranty, I purchased both and they agreed to a 100% refund if I only need one to fix it. Going to start with the contact switch first and see if that does the trick. I’ll keep you posted.
Joe & Cynthia
10-12-2022, 06:16 AM
One small item to keep in mind for solar systems
For those of us with solar panels it makes a complete reboot of the RV a bit more complicated. One of the items I intend to add are some on-off switches in front of the two solar controllers. That way I can be sure that when all switches are off, the RV has no power.
2022 DynaQuest XL 3400KD CabOver, WD, Lithium Batteries, 4 190Watt Rigid Panels, extra inverter for AC operation w/o Genset.
10-12-2022, 07:06 AM
The solar power goes from the solar controller to the batteries. So when you shut the main battery disconnect off in the battery bay, its my understanding you will be effecting a full coach shut down, of the DC component. The solar controller will still show power, but only because it is being fed from the panels and not going past that.
10-15-2022, 03:12 PM
Update: Called Equalizer Systems. Tech was 90% sure it was a contactor. Reminded me that is what he gets paid to do…diagnose problems. So, since I am out of warranty I purchased a new contactor, which he sold me at about 50% off, which was very kind of him. He also sold me a new Pressure Switch, “just in case” the contactor did not work. He also agreed to take it all back for no restocking fee if it doesn’t work…again, very kind.
I didn’t want to install both at the same time because maybe just one part would fix it. So, I installed the contactor first since he was “90% sure”. Well, not so much. 4 hours later, including a trip to the hardware store for a new clamp (had to cut the original off) I have the same problem. Decided to tackle the pressure switch, but it requires taking the entire hydraulic unit/motor off of the mounting plate because the pressure switch is literally right up against the generator, leaving no room to unscrew the switch. Then I re-read the instructions and it says you must relieve the pressure before attempting to remove the old pressure switch. No can do, since the way you relieve the pressure is by putting the jacks down, according to the instructions. Well, my jacks are stuck in the up position making that impossible.
Bottom line, I’m exactly where I was before I installed the new contactor, lost 4 hours of my life and I will be back on the phone with Equalizer come Monday!
Joe & Cynthia
10-16-2022, 04:43 PM
JSaylor
Sunseeker MB jacks
Mine are not working also. What circuit are they on? All wiring looks good. I could barely move them manually until I pulled the motors. Where do I look. The rig is new to me. Thanks!
10-16-2022, 06:46 PM
We are talking about the Equalizer Systems jacks on Dynamax Freightliner M2 based motorhomes. There is no way to move these manually. Do you have an Equalizer Systems unit? Just not sure we are talking apples to apples here.
Joe & Cynthia
10-28-2022, 12:47 PM
Update: before tackling the pressure switch, I called Equalizer Systems again. Got a different tech than the first 90% sure guy. This time I was told to first unplug the yellow wire with the black line on it from the pressure switch. If the lights on the controller go out, pressure switch is bad. If the lights don’t go out, then it is bad controller. Did that and the lights did not go out. So, I now have a $600 controller on order and I am returning the the contractor and pressure switch previously purchased.
I am now at the beginning of the 3rd week trying to get this issue fixed. Hopefully, the controller arrives today and the problem is solved.
To be continued…
Joe & Cynthia
10-31-2022, 08:57 PM
Controller arrived. Installed…no joy. Did further testing and now Equalizer believes the motor is bad. Call me frustrated after 3 weeks.
Joe & Cynthia
10-31-2022, 10:35 PM
Bummer. Can you return the controller?
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
11-01-2022, 08:44 AM
Yes, Equalizer has been really good to work with. They are allowing me to return the part without their normal 20% restocking fee and they are paying the return freight.
The new diagnosis is a bad motor and possibly the pump. The new assembly is being shipped today. Hopefully, this will be the final attempt and I will have working levelers.
Joe & Cynthia
11-01-2022, 08:48 AM
Nice to see some companies still actually care, probably why Dynamax chose them.
-2017 Isata 5 35DB (bunkhouse)
#teambunkhouse
