04-01-2018, 07:11 AM
#21
Hi, received my Bluetooth module and tried connecting yesterday. Anybody help with some questions?
Once I fitted. The original keypad is completely dead, will not power on or anything? Is that normal? I then tried connecting, it found the module but when following the password connection nothing happens. I kept the left and right pressed but nothing. Any ideas?
04-01-2018, 01:11 PM
#22
Following this because Halla made me spend $400.00 on pads and the blue tooth module. I’m a victim!
Scott & Heather
2018 Isata 5 DS
04-01-2018, 02:05 PM
#23
Lol. Mine plugged in and worked the first time.
Are you sure your number on the back of the control pad matched? I wonder if it blew a fuse? Call equalizer, someone posted they are easy to work with.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
04-01-2018, 04:31 PM
#24
Unless there’s a fuse inside I have not. The system works perfectly until I plug the module in. Then I have no power to the manual panel, nothing works. The app finds and connects with my phone but nothing happens when I hold the buttons, on the manual panel to get the pass key. Tried again today and no different. I’ll phone equilizer tomorrow. Beginning to think mine must be faulty.
04-06-2018, 06:57 PM
#25
Turns out the one they sent me was faulty. Received a new one yesterday and fitted today. Everything works perfectly. Great addition to the MH.
04-06-2018, 07:01 PM
#26
Hi, are you using the andriod or Iphone app
My Andriod app still won't stay connected. They are working on the APP according to tech support
Thanks,
Walt & Cindy
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
04-06-2018, 07:13 PM
#27
Using the iPhone app. Only tested briefly and it stayed connected.
04-06-2018, 07:25 PM
#28
Thank You
Thanks, Hope they get my andriod app working soon. I installed my snap pads yesterday & It was hard yelling to DW, up, no down, no the other up!! http://www.forestriverforums.com/for...milies/eek.gif
Cindy & Walt
2018 DX3 36FK
2015 JKHR - toad
04-07-2018, 06:58 AM
#29
Iphone, and it stayed connected while in use
04-10-2018, 04:21 PM
#30
Installed my BT Equalizer module and Snap Pads today. With the BT module it is a simple one man 5 minute job. The module works great and the pads look good although they will add 36lbs. of weight.
Scott & Heather
2018 Isata 5 DS
04-10-2018, 07:15 PM
#31
Nice, hoping this is on my list this week. I am making progress.
04-10-2018, 08:51 PM
#32
I can’t believe I am passing you up on mods!!!!! You better take a day off soon.
Scott & Heather
2018 Isata 5 DS
04-11-2018, 07:14 AM
#33
I worked all weekend, got a lot accomplished. I have bead blasted the generator exhaust tip, painting that black to match, ordered a new exhaust tip for the truck exhaust (man that is a big pipe). changed kitchen faucet out. I ordered a full set of truck steps, getting them powdercoated to match the truck as we speak. I added bed lift struts and built custom built in storage bins under the bed.
I have piles of stuff to install, just trying to wrap my ahead around a proper order to install.
Dont worry, I will get caught up.
04-11-2018, 07:19 AM
#34
Do you have a link to those bed struts? I need to add that to my list. Waxing is today.....
Scott & Heather
2018 Isata 5 DS
04-11-2018, 07:27 AM
#35
Waxing is my last item on the list, I want to wax everything two times after I buff, then I will install the new exterior mirrors, truck steps and finally the awesome Caliber 9 grille.
Here is that link, you have to measure based on your space required, they walk you through it.
RV Bedlift Kits
04-11-2018, 07:52 AM
#36
I need pictures of your storage! Been trying to figure out what to do there
2016 Dynamax DX3 - Big Blue
04-11-2018, 08:03 AM
#37
My storage garage? or my storage bins?
04-11-2018, 08:04 AM
#38
Bins under the bed
Edit: er whatever you ended up doing under the bed for storage
04-11-2018, 08:10 AM
#39
Or that storage. LOL. There is a heat duct that runs across, so I had to raise the floor to get over that. I used 2x2 for the structure, bed lift struts and then 1/4" finished plywood for sides, 1/2" for bottoms, with a speaker type carpet, spray glue etc..
The last pic, I added a similar shelf under the sink in the bathroom, keeps the stuff from falling behind that false wall, and more storage.
I can get better pics later, these are kind of dark.
04-11-2018, 08:17 AM
#40
The left bin is a lot deeper, enough for plastic totes.
