Maybe...
Originally Posted by Bob2019
Your suggestion makes sense but won't work here. So little room for all those splices and shrink tubing in the awning arm with the controller at the bottom of the arm using most of the space. Three of the cables that contain wires that are above the controller and 3 are below with about 4" length to cut and splice on the ones below. I had a hard time with the 6 cables and twelve splices to jam it all back to the top of the connector. Currently, as I noted Lippert has sent a second controller as the little green light keep blinking (should not) indicating either a bad controller or moisture somewhere else causing a level 2 fault. Pulling all that wire mess out again to change the controller will probably require inspection of the splices and more liquid tape applied as movement breaks the seal of the liquid tape.
Maybe ask Lippert to send you the controller AND a new complete wiring harness.
Larry
