Question:
- with the air conditioner turned off at firefly and idle for at least an hour
- go to setup / network diagnostics / air cons
- Are the indicators next to freeze sensor and coil freeze illuminated?
If the alarms are not illuminated with the AC off and at ambient temps, then it is probably a valid alarm, and need to follow troubleshooting for a freeze sensor problem. Some of those are that the sensor has fallen off the coils, blocked filters, operation in too cool temps, etc. Prolly some info in the HVAC forums.
If the freeze sensor alarms remain activated when the a/c has come to ambient temp, then it might be a problem with the sensor itself or firefly reading the sensor.
2021 Isata 5 28ss 4x2 / 2020 JLU Rubicon
Prior: 2016 Lance 1995 / Ram 1500 Eco Diesel
2012 Lance 1575 / 2015 Jeep JKU Rubicon
