Old 02-28-2021, 02:55 PM   #1
Freightliner M2 DX3 Cabin Air Filter
My wife saw an article on a Super C website about the cabin air filter in the M2 chassis. I checked & it does have one hidden behind the panel on the passenger seating area labeled ' Cabin Air Filer Access'. The panel/cover is secured w/ 3 T20 Torx screws. After the cover is removed a vertical cover plate is visible, & is held on by 6 T20 Torx screws. The #6 top screw isn't visible in the picture because it's hidden by the dash panel. The panel has to be pushed upward slightly so you can insert a screwdriver. The screw just has to be loosed a few turns so the cover panel can be swung to the left side. The filter is on the right side of the opening, & just pull it out. Mine was full of pine needles from where I park the RV, & other bugs & trash.
I found a replacement filter on Amazon for under $10 - some places wanted almost $40 for a filter. Time to do this should be less than 30 min.
ID:	248573   Click image for larger version
ID:	248574   Click image for larger version
ID:	248575   Click image for larger version
ID:	248576   Click image for larger version
Silver Arrow is offline   Reply With Quote
Old 03-01-2021, 07:57 AM   #2
halla's Avatar
I change that filter once per year, it gets really nasty. The air intake is right on top of the passenger side firewall, so a lot of debris etc... goes down into that filter.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
halla is online now   Reply With Quote
Old 03-01-2021, 01:08 PM   #3
TRN
I changed mine for the first time this past week, not sure it had ever been done and it was filthy! It's now on my yearly to do list.
2015 DX3 37TRS - Brutus
B'ham - or at a racetrack
TRN is offline   Reply With Quote
dx3
